DonMuncy Posted December 20, 2024 Report Posted December 20, 2024 Can someone who uses FlyQ's EFB tell me how to open the Airport Facilities Directory? I know it is in there, but for the life of me, I cannot figure out how to get into it. When I update the data, I have the button pushed that says the AFD should be updated as well.
PeteMc Posted December 20, 2024 Report Posted December 20, 2024 I was curious, so I just pulled down their manual. I can find no reference to chart supplement, supplement, afd, a/fd, clearance, delivery or anything else that would be in the AFD. The Airport section seemed get the most hits, but even that didn't seem to have everything. At least from what I can tell with the manual. Are you sure they have it?
Igor_U Posted December 20, 2024 Report Posted December 20, 2024 The way I get to AFD is to type the Airport identifier in search field and select it to get a "general" info on the airport. There's 7 tabs on top to select and one is AF/D.
DonMuncy Posted December 22, 2024 Author Report Posted December 22, 2024 On 12/20/2024 at 5:40 PM, Igor_U said: The way I get to AFD is to type the Airport identifier in search field and select it to get a "general" info on the airport. There's 7 tabs on top to select and one is AF/D. I tried following your procedure. I type in my airport, and hit select, but I don't find a tab for AFD. Any idea what I'm doing wrong.
DonMuncy Posted December 22, 2024 Author Report Posted December 22, 2024 On 12/20/2024 at 5:22 PM, PeteMc said: I was curious, so I just pulled down their manual. I can find no reference to chart supplement, supplement, afd, a/fd, clearance, delivery or anything else that would be in the AFD. The Airport section seemed get the most hits, but even that didn't seem to have everything. At least from what I can tell with the manual. Are you sure they have it? The only thing I know is that when I update my data, one of the options they list is AFD.
Flash Posted December 22, 2024 Report Posted December 22, 2024 Don, using FlyQ+ on my iPhone, I can click on the map near the airport, which calls up a screen showing the airspace, the airport, and a nearby LOM. I then click on my airport's name (not on the Direct, +FP, charts, or map icons underneath it), and that takes me to a screen for the airport. That screen allows me to choose Gen, Wx, Proc, A/FD, Notm, Svc, or Near. If I choose A/FD, it shows me an image of the appropriate pages in the A/FD for the airport. If you're trying to get to another section of the A/FD, though, I haven't figured that one out yet.
DonMuncy Posted December 22, 2024 Author Report Posted December 22, 2024 Thanks guys. I have now found that if I am on the map, I can double tap on the airport. Then when the airport info comes up, I can tap on "common". Then the choices come up which include AFD. I appreciate the responses. 3
Igor_U Posted December 23, 2024 Report Posted December 23, 2024 On 12/21/2024 at 9:20 PM, DonMuncy said: Thanks guys. I have now found that if I am on the map, I can double tap on the airport. Then when the airport info comes up, I can tap on "common". Then the choices come up which include AFD. I appreciate the responses. Don, I might not be clear in my description (I don't have screen grab on a work computer) but if you search for the airport in the top field, you'll get the pop-up window with 4-5 tabs to click like direct to, +FP, Info, app. Plates... Do NOT select that. Please select the airport info above those tabs. it will default into General tab but one of the tabs you can select is A/FD.
