Slick Nick Posted October 12, 2024 Report Posted October 12, 2024 1991 201 MSE. In cruise, with the plane properly trimmed “hands off” at around 150 knots, I looked back and noticed the elevator horns were sticking up into the slipstream a bit. Not sure if this is normal, or abnormal, honestly it’s the first time I’ve looked back there during flight. C of G was fairly forward, just me on board and about 20 gallons of fuel. Has anyone else seen that position before? Again, not sure it’s abnormal, but just something I noticed. Photo attached. Quote
EricJ Posted October 12, 2024 Report Posted October 12, 2024 Totally normal and common. There've been a few threads about this in the past as well. 1 1 Quote
KSMooniac Posted October 12, 2024 Report Posted October 12, 2024 Yep, totally normal. Sent from my motorola edge plus 2023 using Tapatalk 1 Quote
Slick Nick Posted October 12, 2024 Author Report Posted October 12, 2024 Awesome thanks fellas! Quote
Fritz1 Posted October 12, 2024 Report Posted October 12, 2024 interesting, my horns are pointing down in the Bravo in cruise, this may be different between a short body and a long body, I even know a guy with an Eagle that put little fairings at the bottom of the horizontal stabilizer in front of the horns, position may also be dependent on rigging of elevator bungees Quote
PT20J Posted October 12, 2024 Report Posted October 12, 2024 1 hour ago, Fritz1 said: interesting, my horns are pointing down in the Bravo in cruise, this may be different between a short body and a long body, I even know a guy with an Eagle that put little fairings at the bottom of the horizontal stabilizer in front of the horns, position may also be dependent on rigging of elevator bungees M20Ks and later have a bob weight and variable downspring instead of trim assist bungees used in earlier models and trim in flight with the elevator trailing edge up. 2 Quote
blaine beaven Posted October 15, 2024 Report Posted October 15, 2024 Next flight, throw some gold bars behind the back seat (or something else heavy) and see what you get for a deflection. I find on my 78J that the elevator position depends on how the plane is loaded. Quote
BravoWhiskey Posted October 15, 2024 Report Posted October 15, 2024 Like @Fritz1 mine point slightly down on the Bravo. All the rigging and trim is good so I think nothing of it. First time I noticed it I tried playing around with the trim… ended up being a waste of time. It seems to change slightly depending on weight and balance and speed but only slightly. Quote
