Will.iam Posted September 27, 2024 Report Posted September 27, 2024 Well I flew 10 days ago multiple stops no issue had my plane on battery minder for all 10 days and when i came out to start it the battery slowly turned the prop over and then stalled. I looked in the logbook for when the previous owner installed the battery and i could not believe it 1 Apr 2011! That battery owes me nothing! That is an amazing 13 year 5 month streak! I was just surprised that i got no warning at all acting more like a lithium ion battery than a lead acid and my last annual they said my battery pasted the test. I am just as shocked at the increase in new battery prices with most wanting $1000 i found chief’s had a special for $849 for RG24-16 battery which i only hope goes as long as the one that was in there now. 2 Quote
EricJ Posted September 27, 2024 Report Posted September 27, 2024 2 hours ago, Will.iam said: Well I flew 10 days ago multiple stops no issue had my plane on battery minder for all 10 days and when i came out to start it the battery slowly turned the prop over and then stalled. I looked in the logbook for when the previous owner installed the battery and i could not believe it 1 Apr 2011! That battery owes me nothing! That is an amazing 13 year 5 month streak! I was just surprised that i got no warning at all acting more like a lithium ion battery than a lead acid and my last annual they said my battery pasted the test. I am just as shocked at the increase in new battery prices with most wanting $1000 i found chief’s had a special for $849 for RG24-16 battery which i only hope goes as long as the one that was in there now. Did your area have a significant temperature change over that time? An aging AGM that is near end-of-life will sometimes just give up the ghost completely without warning, which sounds like what happened to you. This is the usual means of automotive battery death in AZ, it just quits either in the fall when it cools off or in the spring when it first gets hot. Quote
Shadrach Posted September 27, 2024 Report Posted September 27, 2024 2 hours ago, Will.iam said: Well I flew 10 days ago multiple stops no issue had my plane on battery minder for all 10 days and when i came out to start it the battery slowly turned the prop over and then stalled. I looked in the logbook for when the previous owner installed the battery and i could not believe it 1 Apr 2011! That battery owes me nothing! That is an amazing 13 year 5 month streak! I was just surprised that i got no warning at all acting more like a lithium ion battery than a lead acid and my last annual they said my battery pasted the test. I am just as shocked at the increase in new battery prices with most wanting $1000 i found chief’s had a special for $849 for RG24-16 battery which i only hope goes as long as the one that was in there now. I got about the same out of my last Concorde. Mine failed a load test last year but I could tell it was loosing capacity. Not worth pitching though. I keep it fully charged in my hangar. Quote
LANCECASPER Posted September 28, 2024 Report Posted September 28, 2024 5 hours ago, Will.iam said: Well I flew 10 days ago multiple stops no issue had my plane on battery minder for all 10 days and when i came out to start it the battery slowly turned the prop over and then stalled. I looked in the logbook for when the previous owner installed the battery and i could not believe it 1 Apr 2011! That battery owes me nothing! That is an amazing 13 year 5 month streak! I was just surprised that i got no warning at all acting more like a lithium ion battery than a lead acid and my last annual they said my battery pasted the test. I am just as shocked at the increase in new battery prices with most wanting $1000 i found chief’s had a special for $849 for RG24-16 battery which i only hope goes as long as the one that was in there now. 24-16 is not your battery model. You need either a 24-15 or a 24-11. https://batterymanagement.concordebattery.com/BatteryDocs/finalfaapma.pdf Quote
Red Leader Posted September 28, 2024 Report Posted September 28, 2024 That happened to the battery in my last plane. A few years ago, I flew to another airport to discuss avionics upgrades with the shop but when we went to leave, the plane would not start. We got a jump and flew home but the battery refused to spin the prop after shutdown. Talk about sudden with no warning! I don't remember how old it was but I do not believe I got near the life out of it that you did with yours - well done! My replacement, at the time, was around $600. Quote
Hank Posted September 28, 2024 Report Posted September 28, 2024 My 12V Concords average around 7 years. I'm happy with that. I write the installation date on top with a Sharpie. Quote
Will.iam Posted September 28, 2024 Author Report Posted September 28, 2024 13 hours ago, LANCECASPER said: 24-16 is not your battery model. You need either a 24-15 or a 24-11. https://batterymanagement.concordebattery.com/BatteryDocs/finalfaapma.pdf Yea i looked it up but when i opened the battery box there was a 24-16 and it bearly fit the box it was in and considering the 24-15 is bigger than the 24-16 and even concorde says certain m20k have fit issues with the 24-15 i’ll stick with what worked for the previous owner. Thanks for checking i appreciate it. Quote
Will.iam Posted September 28, 2024 Author Report Posted September 28, 2024 16 hours ago, EricJ said: Did your area have a significant temperature change over that time? An aging AGM that is near end-of-life will sometimes just give up the ghost completely without warning, which sounds like what happened to you. This is the usual means of automotive battery death in AZ, it just quits either in the fall when it cools off or in the spring when it first gets hot. Wow that is interesting because literally that was the first morning that i tried to start it with the temps down to 69 degrees. It had been 85 or above all summer. 1 Quote
