Has anyone had any luck with a semi-permanent installation of an FAA-approved (for commercial airliners, anyways) compact oxygen concentrators? I am contemplating an addition of a 12V port and a couple of straps in the back of the plane to run one that I can get essentially for free with prescription. Currently looking at a SeQual Eclipse 5, a continuous flow model.
Edited by varlajo
You cannot mount it permanently without it being signed off.
But what you are proposing seems to be nothing special.
The one that most people in aviation seem to be using is the Imogen G5.  They have tested it with 2 people up to 14,000 and 1 person to 18,000.
One thing to think about is how getting a prescription for O2 will effect your medical.
The Imogen can be bought from a couple of sources without a prescription, but a copy of your pilot certificate.  That is how I got mine.
I had the shop add a power port (cigarette lighter) in the back for it.  Or a cooler.
Are you running your inogen g5 off your 28v system? I thought my cigarette lighter was 12v but surprisingly it was 28v and inogen says not to run it off 28v. Have you had any issues running it off 28v?
Ship system is 14V
Edited by varlajo
1 minute ago, varlajo said:
14V
Yea that’s 12v  system the alternator charges at 13-14 volts, that’s how it charges the battery. make sure you have a 10amp  breaker for the inogen g5 or it might be tripping the breaker.
8 minutes ago, varlajo said:
Ship system is 14V
Yes i was replying to pinecone as his mooney is like mine a 28v (24v system) and he said he is running his through his cigarette lighter so was curious if he had a plug that stepped down the voltage or was his inogen running fine on 28v.
I purchased the kit that includes a DC-DC converter to convert the 28 volts to 12 volts.  https://www.inogenaviator.com/
FYI,, the company selling them to pilots is Main Clinic Supply
Just for info purposes, the person I bought my Inogen G5 from is Jon Abbotts at Pure Medical www.puremedco.com 720.425.5454, 888.747.7590
Yes, someone else has run a cig lighter into their baggage compartment and uses it to run a G5.  I also use a g5, however, I use the batteries currently because the cig power required is significant.  I have a 5amp CB on my 12v cig charger and it requires something like a 12amp cb for a 12v system.  If you wire one, make sure you get the correct power setup.
Thanks! Based on my calculations, I need a 10 amp breaker.
I know G5 is "rated" to 10,000 ft. Does it work and make a difference at higher altitudes, say 15,000?
Yes, it works well.  I actually have a splitter and use it for my son and I.  I use a pulse ox and it keeps me mid 90s.  I’ve used it up to 14,500’ and it works fine, however it was on the highest setting for two of us at that altitude.
Be careful with the power required, here’s a picture of my DC power coord for the g5.  It seems to say 10amps required, so you’ll need a bigger breaker than that.  Actual power draw at different settings was hard (impossible) to find in the manual.
