M20M here i go again..chasing a Dre symphony issue and a20 vs a30 question
My intercom worked perfectly in the '98 m20m when I flew it on Saturday, then I started the plane Sunday morning, and the headset would not provide any sidetone, and I could not transmit to ATC through the headset mic. I was, however, able to communicate with ATC on the ship mic and speaker, so the radios are all working . Then all of a sudden I had no sidetone and no comms with atc over the headset, I must have screwed up something, cant determine what went wrong.
SO;
I need a Dre Symphony manual, does anyone have one they could send to my email
I need to figure out if I screwed up a setting and muted something
it could be the transmit side of the intercom, or the KMA 24
I either did something stupid and hit a setting, or maybe my headset was dead.
It is a tricky troubleshooting situation.
If it is my headset  ( an a20 ) , and if I have to replace it, would anyone here vouch for the a30 over the a20
there is a mooney group on facebook and lots of negative a30 comments.
All thoughts and recommendations appreciated
Peter
SO;
Peter
I’m not really any help, but if it’s definitely the a20, I’d send it back to Bose.  Last time I did that it came back like new for free.  I think there is a nominal charge if they are above a certain age.
SO;
Peter
Very unlikely that it's your A20.
Very likely that it's a setting. The instructions for your DRE Symphony should be covered in the back section (AFMS) of your POH.
If not here's a copy: https://www.mooney.com/wp-content/uploads/2020/12/DRE-Symphony.pdf
If it's not a setting on the DRE, I would look over all of the buttens and the knobs on your KMA24 Audio Panel. If it's not a setting, most shops will have a KMA24 Audio Panel on the shelf they can slide in and see if that's the problem.
9 hours ago, BlueSky247 said:
You don’t have any other headset around to test with?
yes, it was one headset, the mic not working, and no sidetone; then I tried that headset with my handheld and as well through the copilot seat plugs. I got mixed results and even some funky behaviour when using the PTT on the pilot yoke.
Honestly, allot of variables to emulate the same thing I experienced, very frustrating
I don't think it is the a20 either  . ill keep working on it. and honestly, I think I've screwed up a setting on the dre. That thing was pretty sophisticated in its day , but it is long past its best-before date.  I've had this plane for 7 years and never had this issue, so maybe my personal best-before date is coming up as well!
Thank you for sending this along, I know this is in the plane but I'm far from the machine today. much appreciated. I probably screwed up something without realizing it.
I've had the plane for 7 years and this was a first for this issue. Probably DRE or kma 24 pilot error on my part.
Thanks Peter
