00-Negative Posted January 11, 2024 Report Posted January 11, 2024 Started flying my M20E in September and have put around 40hrs on it since purchase. I noticed the RAM air door had a small gap around the top and sides. Looks the the seal is either completely deteriorated or was removed and looking back at pictures I took when I bought the plane, it was like this when I purchased it. LASAR does not have the seal in stock. I'll prob replace with baffle seal material next week. Here's my question: I need to fly my wife/girls this weekend to a cheer competition. I sold them on the plane by convincing them that we would use it to fly to these competitions and we already had to drive the first one d/t weather. They're eventually going to figure out that I spent all of our money on a plane for me. Can I cover the RAM air door opening with 3M aluminum foil tape temporarily until I replace the seal? Thanks, David 1 Quote
Shadrach Posted January 11, 2024 Report Posted January 11, 2024 You can make a seal out of rubber gasket material (1/8” IIRC). You can buy sheets of it at your local auto parts store. I would not bother taping it up unless you live in a dusty environment. You’ve been flying it as is since you bought the plane, another flight isn’t going to make a difference. Depending on environment, you might see elevated silicon in the oil from running without a gasket. It’s an easy fix. I would take care of it ASAP... 2 Quote
00-Negative Posted January 11, 2024 Author Report Posted January 11, 2024 Yes sir. Thanks for the response. I might be able to get it done tomorrow. Quote
201Steve Posted January 11, 2024 Report Posted January 11, 2024 1 hour ago, 00-Negative said: . They're eventually going to figure out that I spent all of our money on a plane for me. Hahahahahah 1 Quote
Ron McBride Posted January 11, 2024 Report Posted January 11, 2024 Before flying, find the old seal and remove it. The old seal can block air going into the fuel injection system. No air, no power… 1 Quote
RobertGary1 Posted January 13, 2024 Report Posted January 13, 2024 If be careful putting anything on it. Anything making it past (including ice, tape, etc) can go straight to the impact tubes and stop fuel flow. Quote
Fly Boomer Posted January 13, 2024 Report Posted January 13, 2024 On 1/11/2024 at 8:32 AM, 00-Negative said: Here's my question: I need to fly my wife/girls this weekend to a cheer competition. I wouldn't change anything just before the flight you describe. If there is an incident, you won't have to worry about them "finding out eventually". Quote
