Tso Teflon assys
Hose information on each assy
Heatshrink over band clamps to protect and seal
The firesleeve is skin tight as it’s installed before last fitting .
Clear Shrink on manifold psi assy to reduce chafe and keep clean.
I suggest blue or white adel clamps only
201-mse  shown
The lay line information helps the owner and the mechanic in the  routing of the hose assy.
no other vendors do this customization
I stock all Pt6 hose assys
GB
  • Like 5
On 12/22/2023 at 1:17 PM, Gee Bee Aeroproducts said:
Tso Teflon assys
How do these compare with the “brownish” hoses with integrated fire sleeve?
Brown or blue intergral is same hose
if there is chafe in the brown to the hose, it can’t be retested from a rsl for  recertification
slip on can be removed, psi test and resleeve
Slip on colors
orange , black, blue all as1072
all other hose shops on orange per there tso
I rather do Pratt PT6 hoses than piston assys
4250. to 9750.00 each
Different market, different customer
