This isn't necessarily a Mooney-specific question, but posting here because I think it's factory original, and I'm guessing others here with the same clock have answers.  It involves a clock identified as a "Mid-Continent MD-91 (LET)"
Short version: why does this clock have two power connections?
Long version:
If you search for this clock on the internet, you get plenty of pictures, auctions on e-Bay, etc.  But no installation/maintenance manual that I can find, not even at Mid-Continent's factory site.  Below is a picture of the back of the unit, from one of those online surplus sites.  Notice the unit has two connectors on the back.
As I said, I think this is factory-original equipment, though I'm not 100% sure.  Thing is, the factory schematics for our airplane show a clock with only two terminals, not four:
The factory schematics show one of these terminals going to ground, and the other to the battery, through a 5-amp fuse.  That makes sense: this is an old-school electric clock which needs power, and if it's going to keep accurate time, it needs power all the time, which it gets from the ship's main battery.
If I trace the wires from our clock, one pair has a connection to ground, and a wire going down the side of the fuselage - I presume to the battery.  So far so good.
The other pair has a connection to the same ground, and a wire that goes through a 1-amp fuse to a bus bar that is energized when the master switch is turned on.  At first I thought this was some form of redundant power, but that seems unreasonably complex for such a simple instrument.  I'm now thinking it's just a light.  But I haven't flown at night in a while, and I honestly can't remember if this instrument is internally lit or not (even if it is, the bulb may be burned out).
Does anyone have a manual for this clock, or just know what that second power connection is for?  If it's a light, anyone care to speculate why it's on the master switch bus in our airplane, rather than the lighting bus?
That looks like a light bulb in the upper right corner of your picture. Bet it's just on all the time.
I'd all Mid-Continent and see if they can send info.
Looks like if you twist the connector… you get access to the bulb that is attached to it… :)
Like Skip mentioned… it is directly connected to the dimmer circuit of your instrument panel…
So… two sources of power… one gets dimmed, the other doesn’t…
