goodyFAB Posted October 8, 2022 Report Posted October 8, 2022 Question, can anyone offer an explanation why the sealant called out for fuel tank inspection windows/screws is different for the wing walk inspection window ? thank you! 1
Shadrach Posted October 9, 2022 Report Posted October 9, 2022 7 hours ago, goodyFAB said: Question, can anyone offer an explanation why the sealant called out for fuel tank inspection windows/screws is different for the wing walk inspection window ? thank you! The sealant specified for the access panels is non-adhesive. The sealant specified for the wing walk panels is adhesive. Presumably this was specified due to the need for the wing walk panels to withstand the stress of foot traffic. 1
Guest Posted October 9, 2022 Report Posted October 9, 2022 11 hours ago, goodyFAB said: Question, can anyone offer an explanation why the sealant called out for fuel tank inspection windows/screws is different for the wing walk inspection window ? thank you! Sealant for most access covers and windows is of a lower strength, the one under the wing walk needs to be higher strength to handle the weight of standing on it. Later models had a strengthened access panel as well.
Shadrach Posted October 9, 2022 Report Posted October 9, 2022 2 hours ago, M20Doc said: Sealant for most access covers and windows is of a lower strength, the one under the wing walk needs to be higher strength to handle the weight of standing on it. Later models had a strengthened access panel as well. Been a while since I’ve been in there, but I am pretty sure that large panel on my 67 F has a stringer or stringers.
goodyFAB Posted October 10, 2022 Author Report Posted October 10, 2022 On 10/9/2022 at 7:07 AM, M20Doc said: Sealant for most access covers and windows is of a lower strength, the one under the wing walk needs to be higher strength to handle the weight of standing on it. Later models had a strengthened access panel as well. thanks ! that makes sense
