If you have a 28v Mooney and your cigarette lighter adaptor puts out 24 volts and you need to run 12v items this adaptor will work .
Pictures:
https://www.dropbox.com/s/idml7w8r9cxf8af/24-12v adaptor-2.JPG?dl=0
https://www.dropbox.com/s/iop8947td72qsjb/24-12v adaptor-1.JPG?dl=0
https://www.dropbox.com/s/dw6uupy6jpoo6gl/24-12 pic3.JPG?dl=0
$25 picked up locally or $5 shipping (PayPal friends and family or Zelle)
  • 1 month later...
  • LANCECASPER changed the title to 24v to 12v cigarette lighter adaptor - SOLD
  • 2 weeks later...
On 8/2/2022 at 7:51 AM, Pinecone said:
Anyone know if for sure if the 252 is 24 volts at the cigarette light?
How do I order one of these?
Putting a step down transformer in the 24V long bodies came after the mid 90s….
The way to know for sure if your plane is 12 or 24V at the cigarette lighter… is to put a volt meter in the cigarette lighter…
Or check the WnB records to see what is installed…
Or recognize the transformer in the tail cone….
Pretty easy to just measure what comes at the socket…
If you want to add the transformer to an existing plane… not too hard to do that too….
Most modern devices in aviation are capable of taking 24V too…. (Read the details of the device)
Many car and truck products use 24V for the same reason planes do…
PP thoughts only,
