GeneralT001 Posted February 26, 2022 Report Posted February 26, 2022 I'm quickly realizing that I will not have enough room for the GMA345 (audio Panel) + GTN 750Xi + GNC 255A + GFC500 to be stacked on top of one another. The panel is only 12" top to bottom. Which would you make remote...the audio panel or the NAV/COMM? Quote
Marauder Posted February 26, 2022 Report Posted February 26, 2022 I'm quickly realizing that I will not have enough room for the GMA345 (audio Panel) + GTN 750Xi + GNC 255A + GFC500 to be stacked on top of one another. The panel is only 12" top to bottom. Which would you make remote...the audio panel or the NAV/COMM?Audio panelSent from my iPhone using Tapatalk Pro Quote
carusoam Posted February 27, 2022 Report Posted February 27, 2022 Audio panel and transponder are most often voted most likely to be remote mounted…. Their details get displayed on other screens…. Makes a lot of sense if you go all Big G… Makes less sense if you are buying the best individual boxes made by other companies…. PP thoughts only, -a- Quote
Ragsf15e Posted February 27, 2022 Report Posted February 27, 2022 I might also consider using a -650 instead of a -750 and a pma450b audio panel instead of a gma. I love the garmin gear, but the pma audio is superior. I’m sure I’ll get flamed for not wanting a -750, but if you plan to use an ipad with GP or FF as well, all that screen becomes redundant. And looking outside is still important too! 2 Quote
