Started up the plane to fly to work and got this message on the G500. Decided to put the plane back in the hangar and drive to work since I couldn’t find this error message in the manual and didn’t know if it was a safety of flight issue. The shop hadn’t seen this error either and a call to Garmin turn up that there was a magnetic north update in navigation software and if you haven’t had a compass swing to calibrate the magnometer in several years your will need to do one. After I contacted the shop I guess they got 3 other call the day after me. So if you see this message that’s what’s necessary. They didn’t feel it’s a safety of flight issue but recommended not flying in IMC until calibrated. Hope this helps someone else.
That kind of takes the fun out of the morning commute... :)
Thanks for sharing the details...
There will be a few of these getting a message soon...
So let’s see :
Garmin knows my position.
The magnetic variance should be known based on my position.
Garmin should be able to recalibrate it on their own, all they need is you to do a 360.
If they require a shop visit I’d have some questions for their engineers.
3 hours ago, ArtVandelay said:
So let’s see :
I agree! I think they at minimum could have given a prior warning that this would be an upcoming issue. I went out to do a VFR flight but the screen kept X’ing out on taxi so the plane is grounded until they have time to swing it. I also think they should allow some base level access to do a simple compass swing on your own.
If you’re on Beechtalk I would start a thread there, Garmin service follows their forums.
7 hours ago, ArtVandelay said:
So let’s see :
What isn't known is the actual heading of the airplane, which is the purpose of the swing.
9 minutes ago, ArtVandelay said:
Doesn’t the AHRS tell you that?
The AHRS doesn't know direction until it gets aligned by the magnetometer, and the magnetometer has to be swung (calibrated) for errors just like a compass.   Apparently a software update required that to be redone.
7 hours ago, thinwing said:
its not a big deal...ive done it and takes about 30 min while parked on the compass rose
If warned or know it’s coming it’s not a big deal but when you jump into the plane to go to the office it is.
true...ive never seen my g500 show this...you werent by any chance in motion while it was bootin up??Ive seen a ahrs advisory popping up if I got in a hurry and fast taxi with turns whilr g500 was initializing
Well interesting turn of events today. While this is indeed a problem that is occurring with the G500’s it turns out it wasn’t the problem I was having. I was talking to one of the guys at the avionics shop and he happened to ask if I was in the tail cone for anything recently. I told him that I was actually because my electric trim was stuck and I needed to clean the micro switches to fix it. He then explained to me that the Garmin wiring harnesses are notorious for having pins loose contact and if you simply remove the harness and reconnect it that it will take care of the problem. Sure enough problem solved!
Here is the picture I posted of the electric trim and you can see the bundles of wires that lead to the harness. Maintenance induced failures by yours truly.
I wouldn't classify that as a maintenance induced failure if you didn't purposefully disconnect/reconnect or move the connector.   Personally I'd call that a poor quality connector.
Garmin recommends performing a compass swing every 24 months in the G1000/500/600 systems. There are some additional tasks to be done if you have a GFC series autopilot.
