mooneypilot Posted September 23, 2020 Report Posted September 23, 2020 Just now, mooneypilot said: IMG_3076.mov 369.24 MB · 0 downloads Good video of my GFC500 flying a gps approach extremely stable!! Quote
Rmag Posted September 24, 2020 Report Posted September 24, 2020 On 9/10/2020 at 6:42 PM, Scottknoll said: I had the cap come off my PTT button. It was not fun to talk on the radio... I believe this was the cap used to replace it and might be the same for the CWS.https://www.mouser.com/ProductDetail/Electroswitch/SW53AA2?qs=5muX3C0yOnj5E%2FJxlK6wTg%3D%3D Much better... 1 Quote
carusoam Posted September 24, 2020 Report Posted September 24, 2020 Way extra cool, generic Mooney Pilot...! All Mooney pilots should get one of these, or equivalent! It is a short video... the first minute is all IMC... and hard to tell there is an AP hard at work... Then Runway lights appear as if on cue.... Speed, attitude, altitude, all on target... ready to land... Need the external camera... so we can see how exact the plane lined up on the centerline... Thanks for sharing the vid! Best regards, -a- Quote
ZuluZulu Posted September 24, 2020 Report Posted September 24, 2020 20 hours ago, Rmag said: Much better... Which specific part did you order? I checked and it turns out I'm missing mine too. Quote
carusoam Posted September 25, 2020 Report Posted September 25, 2020 ZZ, The switch cap being discussed is posted above... https://www.mouser.com/ProductDetail/Electroswitch/SW53AA2?qs=5muX3C0yOnj5E%2FJxlK6wTg%3D%3D When you get to the site, there is a link to the actual data sheet... https://www.mouser.com/datasheet/2/128/minp17-5206.pdf And that gets you closer to the switch button cap... it gets mentioned in the data sheet... available in two colors red and black... Does that help any? Best regards, -a- 1 Quote
ZuluZulu Posted October 18, 2020 Report Posted October 18, 2020 On 9/24/2020 at 6:18 PM, carusoam said: ZZ, The switch cap being discussed is posted above... https://www.mouser.com/ProductDetail/Electroswitch/SW53AA2?qs=5muX3C0yOnj5E%2FJxlK6wTg%3D%3D When you get to the site, there is a link to the actual data sheet... https://www.mouser.com/datasheet/2/128/minp17-5206.pdf And that gets you closer to the switch button cap... it gets mentioned in the data sheet... available in two colors red and black... Does that help any? Best regards, -a- I now have four of these little actuators on both MIC buttons, IDENT, and CWS. Thanks, MooneySpace! However, the push-button for my speedbrakes is a slightly different (thinner) size, so this part doesn't fit. Has anyone tracked down the right cap for that? Quote
bradp Posted October 21, 2020 Report Posted October 21, 2020 I am really liking the GFC. The YD function on a J is well worth it - it functions like a rudder trim on the way up and down, and smooths out the bumps significantly. Interesting- Mrs was asking whether I was flying or they autopilot was flying through bumpy clouds the other day. Historically, the Ciib was not able to fly through bumps. This one does better than me. 1 Quote
