McMooney Posted January 8, 2019 Report Posted January 8, 2019 Recently had the following installed: gns480, new pma8000g audio panel, (USED)md200-306 indicator and davtron thingy ( oat and voltage ) removed, kx170b, intercom, kma20, king ki-201c other bits and bobs 2nd flight out of the avionics shop, the OBS resolver stopped working. I figured, that's what I get for ebaying airplane parts and purchased a brand new shiny cdi md200-706 well come to find out, the avionics shop hadn't secured the connector. tightened, everything worked. now, I have a brand new CDI in a box which I KNOW I should send back even with the restocking penalty. pretty expensive I know what I should do but what I want to do is remove the old cdi, sell it on ebay and install the new one. talk me out of it Quote
Marauder Posted January 8, 2019 Report Posted January 8, 2019 Recently had the following installed: gns480, new pma8000g audio panel, (USED)md200-306 indicator and davtron thingy ( oat and voltage ) removed, kx170b, intercom, kma20, king ki-201c other bits and bobs 2nd flight out of the avionics shop, the OBS resolver stopped working. I figured, that's what I get for ebaying airplane parts and purchased a brand new shiny cdi md200-706 well come to find out, the avionics shop hadn't secured the connector. tightened, everything worked. now, I have a brand new CDI in a box which I KNOW I should send back even with the restocking penalty. pretty expensive I know what I should do but what I want to do is remove the old cdi, sell it on ebay and install the new one. talk me out of it New is good. Old is bad.Sent from my iPad using Tapatalk Pro 3 Quote
Marauder Posted January 8, 2019 Report Posted January 8, 2019 That help? Sent from my iPad using Tapatalk Pro Quote
Yetti Posted January 8, 2019 Report Posted January 8, 2019 What's the old CDI? Sell it here and then you have to put the new one in. Quote
McMooney Posted January 8, 2019 Author Report Posted January 8, 2019 MidContinent MD200-306, essential a garmin gi106a Quote
Marauder Posted January 8, 2019 Report Posted January 8, 2019 MidContinent MD200-306, essential a garmin gi106a This conversation is bringing back some memories from 2012. I was installing my first GPS, a GTN 650 and the conversation went something like this:“Wow! $9500 plus installation for a Garmin 650! That seems like a lot. What kind of indicator comes with it?”“None, that’s extra.”“What?! Can I reuse my Bendix King CDI?”“No, it won’t support the GPS function.”“What will work with it?”“A GI-106.”“How much is that?”“$2000 plus installation.”“Just for a CDI?”“Yep.”This is how you get snowballed into this.RUN MCMOONEY RUN!Sent from my iPad using Tapatalk Pro 1 1 Quote
steingar Posted January 8, 2019 Report Posted January 8, 2019 I spent so much putting old used boxes in my airplane that now I can barely afford to fly it. 1 Quote
jetdriven Posted January 8, 2019 Report Posted January 8, 2019 6 hours ago, Marauder said: This conversation is bringing back some memories from 2012. I was installing my first GPS, a GTN 650 and the conversation went something like this: “Wow! $9500 plus installation for a Garmin 650! That seems like a lot. What kind of indicator comes with it?” “None, that’s extra.” “What?! Can I reuse my Bendix King CDI?” “No, it won’t support the GPS function.” “What will work with it?” “A GI-106.” “How much is that?” “$2000 plus installation.” “Just for a CDI?” “Yep.” This is how you get snowballed into this. RUN MCMOONEY RUN! Sent from my iPad using Tapatalk Pro When we did the radio upgrade we installed a Sandel SN3308. The box costs 2 grand but it’s rhe same as a Garmon indicator. The labor was a little more but it’s an HSI not a CDI. 1 Quote
