FlyboyKC Posted July 21, 2018 Report Posted July 21, 2018 I think my King KI206 indicator crapped out. It just stopped working. The indicator powers up but that’s it. The receiver seems to work fine and it identifies the VOR strongly, so that’s why I am thinking it’s the indicator. Is there anyone that services these anymore? Neal Quote
N201MKTurbo Posted July 21, 2018 Report Posted July 21, 2018 Did the plug come loose? Do the flags still work? Does the GS still work? Does the needle move at all? Ive fixed three of them That had the same problem. The coil in the movement is wrapped with yellow transformer tape. The adhesive eventually fails and the tape unwraps and jams the movement. You just need to disassemble the movement and snip off the offending tape with surgical scissors and put it back together. I have heard that repair stations are not allowed to do that repair and new movements are not available. Quote
FlyboyKC Posted July 21, 2018 Author Report Posted July 21, 2018 Thanks for the reply. The flags are displayed but none of the needles move. I will check out the tape around the transformer. Quote
N201MKTurbo Posted July 21, 2018 Report Posted July 21, 2018 2 hours ago, FlyboyKC said: Thanks for the reply. The flags are displayed but none of the needles move. I will check out the tape around the transformer. The flags and needles all have separate movements. So if some of them work, most likely the demodulator works, it has power and the drive electronics all work. Quote
carqwik Posted July 21, 2018 Report Posted July 21, 2018 Bevan Rabell...Wichita KS. Fixed mine (KI-205) although it was a problem of being off more than 6 degrees... Quote
McMooney Posted July 21, 2018 Report Posted July 21, 2018 there's a guy in Lafayette Indiana, Lafayette avionics that can fix Anything. repaired my ki-214 when no one else would even look at it. Quote
TheTurtle Posted July 21, 2018 Report Posted July 21, 2018 western avionics rebuilt mine. was in the $1000 range I think. Quote
