Update rough engine....tried it all..
Inspected: fuel lines, gascolator / carb fuel line screens, mags, plugs / leads, muffler baffle blockage, compressions, intakes for leaks....
Turns out the card was running lean. Local shop suggested sending to Burlington, NC for evaluation. Confirmed running lean so I now have overhauled carb on the engine and is running great.
FYI carb had accumulated 1000 hrs and was last overhauled in 2003.
Thanks to all for help and suggestions.
GHW
George... serious thanks for the follow up.  Makes browsing MS even more valuable.  Glad you found your final culprit(s).
