Lionudakis Posted January 22, 2016 Report Posted January 22, 2016 Cleaning up here. No reasonable offer refused. I have an overhauled fuel probe p/n 7740-118, original 6 pack cluster out of a 62C(oil leaked internally, other than that looks great, repairable or parts), oil temp sensor and plug, 2)12v NULITE light bezels (circle w/ no cutouts), NIB voltage regulator (electro delta VR300-14-50), and original MP/FP and Tachometer from a 62C, both in excellent shape, Quote
cctsurf Posted January 24, 2016 Report Posted January 24, 2016 Is there a plug on the back of the cluster or is it individual wires? I need one with the plug and also have a '62... Thanks, James Quote
Lionudakis Posted January 24, 2016 Author Report Posted January 24, 2016 It has the terminal strip. The plug would be nice. You could cut the plug off and put terminal ends on still, it's 2 fuel wires, oil temp, CHL temp, amperage and a ground. 6 total if i remember right Quote
cctsurf Posted January 24, 2016 Report Posted January 24, 2016 I'm gonna keep out for one with the plug, I want to have one available for backup. I'm seriously considering upgrading to the JPI EDM-900... Just so I wouldn't have problems accessing replacement parts. Thanks, James Quote
missionarypilot Posted January 26, 2016 Report Posted January 26, 2016 I sent a PM a couple days ago about the Nulites and the volts/amps digital indicator if you still have them. Quote
Lionudakis Posted January 26, 2016 Author Report Posted January 26, 2016 Lights are gone. Volts/Amps I still have. I'll check my pm Quote
C-GHIJ Posted January 28, 2016 Report Posted January 28, 2016 What do you want for the fuel probe? Lee Quote
Raptor05121 Posted February 1, 2016 Report Posted February 1, 2016 PM sent for manifold and fuel press gauge. Quote
par Posted February 2, 2016 Report Posted February 2, 2016 What would you like for the gauge cluster? Quote
Lionudakis Posted February 17, 2016 Author Report Posted February 17, 2016 Sorry folks, been busy and haven't checked this in a while. Gauge cluster, nulites, volt/amp gauge, fuel probe and manifold/fuel pressure SOLD Quote
