Marauder Posted January 5, 2014 Report Posted January 5, 2014 I had to have my prop seal replaced outside of the normal overhaul cycle. Is the second leak the seal on the pan? Or is the pan itself leaking?
isaacpr7 Posted January 5, 2014 Author Report Posted January 5, 2014 I had to have my prop seal replaced outside of the normal overhaul cycle. Is the second leak the seal on the pan? Or is the pan itself leaking? I believe it is the seal because it is where you can see the old burned caked up oil along the seam line.
Marauder Posted January 5, 2014 Report Posted January 5, 2014 I believe it is the seal because it is where you can see the old burned caked up oil along the seam line. That's good news! A cracked pan would be a much more expensive headache.
isaacpr7 Posted January 5, 2014 Author Report Posted January 5, 2014 That's good news! A cracked pan would be a much more expensive headache. Chris, You mean I can't just stick a piece of gum on it and call it good? LOL! Happy new year bud
Marauder Posted January 5, 2014 Report Posted January 5, 2014 Chris, You mean I can't just stick a piece of gum on it and call it good? LOL! Happy new year bud Sure you can, it just last for 10 minute flights Happy New Year!
Andy95W Posted January 5, 2014 Report Posted January 5, 2014 Isaac- thanks for the update. Great idea about the inspection camera. Good luck.
