I'm assuming that by "lost" you mean the trim switch no longer works? I'd suggest you remove it from the yoke and clean it first. As you remove it check to be sure there are no loose/disconnected wires. There are two parts to the switch and both have to move simultaneously to activate the trim. Also the contacts get dirty so an electrical cleaner should be used. Search this forum for additional help as this has been discussed before.
Before you zero in on that trim switch make sure your trim disconnect switch (red botton) isn't the culprit. Ditto on cleaning the trim switch but if that bed button is shorted you won't know if the trim switch works. I went through this a couple years ago. I thought I was looking at an $800 part. But instead a very good avionics guy in Griffin, GA charged me 1/2 hour to clean the contacts on that red button. It's worked great ever since. Good luck!
