Hi all,
I'm having trouble finding a replacement spinner doubler part no. 940003-501.  This is for a 1978 J.  It looks like this part was installed after this airplane left production as a result of SB M20-201 2-14-78.  If this part is unobtainium... what are my options?  Can a doubler be riveted on, or is my only option to use the old part as a template to fabricate a replacement?
I am not certain, but i would expect that to be a Hartzell or McCauley part depending on prop and would suggest checking with a prop shop.
On 7/12/2025 at 10:14 AM, IvanP said:
It is listed as part of McCauley spinner for 201.
Thanks!  My A&P thinks this is repairable, but if not I'll start chasing down McCauley / prop shops
I wasn't able to find a replacement, but fortunately a local A&P / IA who specializes in these kinds of repairs came to the rescue.  I don't know what this will do to the balance / vibration but as I've had some prop work done at the same time I'm going to get it dynamically balanced anyway.  Any recommendations for a shop in SoCal / Southwest...?
