eman1200 Posted May 19 Report Posted May 19 ok, in lieu of me overusing the word "thingy" to describe what's going on, here's a nice clean AI description of what I'm looking for: Skytronics Magneto Harness – General Description & Issue System Overview (4-piece assembly): Nut – Secures the assembly externally. Collar – Located under the nut, sits atop the blue lead sleeve. Blue Lead Sleeve – Insulating outer cover of the ignition lead. Round Insert (Ferrule/Pin Seat) – Positioned between the center conductor (core) and the blue sleeve; this component compresses (or pinches) the blue sleeve into the collar when the nut is tightened. Original Design: A threaded pin spins into the center conductor (core) of the ignition lead. This pin provides a secure electrical connection and mechanical engagement within the magneto harness cap. Your Current Setup: Instead of a threaded pin, your configuration uses a crimped pin. The pin is crimped onto the exposed core of the ignition lead (not threaded). The pin is what I'm looking for, part # or where to find would be fantastic. I checked "thingies-r-us" but since skytronics isn't around anymore, I had no luck Thank you! Quote
