Bolter Posted January 2, 2025 Report Posted January 2, 2025 During a longer flight, in and out of cold clouds for the last 1.5 to 2 hours, I had run the TKS a fair amount. Proactively, or it worked as a protective coating, as I never picked up ice. Regardless, it was run for more fluid than any previous flight. When parking the plane, I noticed smoke coming from the cowling. Not a burning oil or fuel smell, and no particular color, like it was steam. Today I opened up the cowlings and found no visible problems, burn marks, smoke stains, etc. Could not recreate the smoke with ground running, either. One possiblity is that it was TKS fluid blowing back into the engine and accumulated enough that it was boiling off when I parked. Are more experienced TKS users seeing that after longer flights? @CAV Ice might also have some practical comments on this, so adding him here.
Fritz1 Posted January 2, 2025 Report Posted January 2, 2025 landed with the system running once, temp below freezing, forgot to turn off after landing but no smoke after shutdown, makes sense that the TKS fluid evaporating would produce a smoke plume under certain temp / dewpoint conditions but never seen it 1
Fly Boomer Posted January 2, 2025 Report Posted January 2, 2025 I think it was Maxwell who told me that in flight, that stuff goes everywhere, so it would not surprise me if enough got around the engine somewhere and was burning or steaming off. 1
exM20K Posted January 3, 2025 Report Posted January 3, 2025 @Bolter that is common and nothing to be concerned with. It is excess fluid steaming off. -dan 1
Bolter Posted January 3, 2025 Author Report Posted January 3, 2025 2 hours ago, exM20K said: @Bolter that is common and nothing to be concerned with. It is excess fluid steaming off. -dan Good to know.
