MikeOH Posted August 16, 2024 Report Posted August 16, 2024 @gwav8or Are you sure you have SOS (shower of sparks; makes buzzing sound) or Slick-Start (electronic; no sound)? 1
gwav8or Posted August 16, 2024 Author Report Posted August 16, 2024 1 hour ago, MikeOH said: @gwav8or Are you sure you have SOS (shower of sparks; makes buzzing sound) or Slick-Start (electronic; no sound)? Well not 100% sure but I am 99% sure it's an SOS. The plane is pretty stock and IIRC I did see the SOS module when the cowl was off last. But again, not 100% sure.
MikeOH Posted August 16, 2024 Report Posted August 16, 2024 11 minutes ago, gwav8or said: Well not 100% sure but I am 99% sure it's an SOS. The plane is pretty stock and IIRC I did see the SOS module when the cowl was off last. But again, not 100% sure. Hmm, I'm pretty sure the SOS was INSIDE the cabin; not firewall forward.
Brent Posted August 17, 2024 Report Posted August 17, 2024 Update on the ignition issue: apparent wiring issue from the SlickStart box to LH magneto. The logbook entry reads "corrected wiring from SlickStart Pin 1 to L/H capacitor." If I understood correctly, the #1 pin wire was connected to the L/H mag ground rather than the capacitor. Since the engine was cold-starting and running fine and if I take the solution at face value, I assume this wiring issue allowed the engine to cold start and run and only manifested as a problem in a hot start scenario. Thanks for the feedback. If the solution sounds off base to folks more knowledgeable, I'm interested to know. Meanwhile, plane is back in my own hangar. 1
gwav8or Posted August 17, 2024 Author Report Posted August 17, 2024 16 hours ago, MikeOH said: Hmm, I'm pretty sure the SOS was INSIDE the cabin; not firewall forward. Well, now I'm not so sure about my SOS..... lol
