Voltage regulator removal
For anyone wishing to install a LifePO4 “lithium iron” sometimes called, be sure to compute your weight and balance prior to spending those big bucks.
Now I’m a tremendous fan of LifePO4 batteries, just replaced four 85 lbs of Trojan lead acid batteries in my golf cart with four 25 lb LifePO4’s, gained everything and lost a bunch of weight and the weight in an airplane can be an issue, especially if the battery is used as ballast like it often is in a Mooney.
On 12/1/2023 at 6:05 PM, Kerrville said:
It’s all done. Will pick it up Monday and see how it goes. Will post the results.
How’s it looking?
Just flew it. New zephtronics regulator and new Concorde battery. Ran great. No lights!  Was a great day, fixed my trim, a strobe light and got the dme working. Now just need to figure out the tail position light…
thanks for all the help!
