Hey everyone, I have a whole lot of used avionics that were recently removed from my Mooney (see my panel upgrade thread in the Avionics section).  I'm posting these here, as well as eBay, Facebook, etc, however I'm listing the prices here at least $100 less per item, and they're negotiable.  (These are my best guess at a fair price, based on eBay completed listings, I'd be interested in any reasonable offer)
I have photos of all of these, and I'm happy to FaceTime you, send other photos, offer local pickup in Orlando, FL, or whatever else makes you feel comfortable.
Everything listed here was working when it was removed.  I don't have 8130s, just as-removed tags from the avionics shop, sorry.  If listed, I have the tray and/or backplate, if not, I don't have it.
edit: Shipping not included but I'll use whichever service you prefer.  Also if you have any issues with any of the items, you can return it to me for a refund within 60 days.
Anyway, here's the list:
Avionics for Sale
Garmin GI 106A CDI - $800 (Sold)
United 5035P Encoding Altimeter - $100 (Sold)
SigmaTek EA5175 Airspeed Indicator - $200 (Sold)
Electric Gyro Corp 1394T100-3Z Turn Coordinator - $200 (Works ok but spins down in ~45 seconds on a bench test) (Sold)
United Instruments 7000 Vertical Speed - $50 (Sold)
Rochester 6247-00199 Mooney J Instrument Cluster - $300
Aspen 910-00004-001 Analog Converter Unit - $200 (Sold)
Garmin GTX 330ES Transponder w/ Tray and Backplate - $1600 (Sold)
King KC-191 (KAP-150) 14v Flight Computer - $1600 (Sold)
Bendix King (Honeywell) 200-2960-00 Trim Switch - $300 (Sold)
Garmin GMA 340 w/ Tray and Backplate - $800 (Sold)
King KS-177 Pitch Servo w/ Bracket - $200 (Sold)
King KS-178 Roll Servo - $200 (Sold)
King KS-179 Pitch Trim Servo w/ bracket - $200 (Sold)
Insight G3 4 Cylinder Color Graphical Engine Monitor - $700 (includes sensors and harnesses, see down thread) (Sold)
OAT/EGT Gauge - $50 (Sold)
Panel Clock - $50
IAI 950D0311-001 Fuel Pressure Transducer Amplifier (14V) - $300
IAI 950D0311-002 Oil Pressure Transducer Amplifier (14V) - $300
I also have a Garmin GNS480 that's currently sent out for battery replacement, but I will offer it here when it comes back.
1 hour ago, Robert Hicks said:
I’ll take the 106a. Does it come with the connector?
Hey, unfortunately I don't have the connector, but it looks like a pretty standard thing.
Just now, gmonnig said:
Does the insight g3 come with the probes in the background of the picture?
Yes, I believe it's all 4 EGT, all 4 CHT, and a few others.  None of it was labeled unfortunately so not entirely sure.  Caveat that I've previously had bad luck with EGT probes that have been removed and reinstalled, but they're included in any event.
I can get a better photo of the probes if you like.
Sure, that'd be great. I have and EI EGT gauge but I'm not sure if they are compatible with the Insight. I hate the EGT gauge I have because you have to select each cylinder to tread the value, not like a bar graph.
I actually quite liked the Insight G3 other than it was so small.  Nice little unit.  Will send you a PM.
Dug through the "bag of sensors" and figured out what I have for the Insight G3:
4 x EGT
4 x CHT (one of which appears to have provisions for a factory CHT gauge also)
Oil Pressure
Oil Temperature
OAT
Vibration Sensor
Miscellaneous Insight connectors
All of this is included with the Insight.
11 minutes ago, N201MKTurbo said:
BTW, your clock says it will work on either 12 or 24 volts.
Good catch, should have checked more closely
Found a few more items (transducer amplifiers) in my box of parts, and some photos of some of the items I didn't post photos of before.
