WAFI Posted October 11, 2022 Report Posted October 11, 2022 Looking for some help regarding witch engine drive fuel pump part number is correct. I've found a few that seem to to have the same specs but 100% sure on which one. IO-360-A3B6D 1977 "J" @PT20J@carusoam Quote
carusoam Posted October 11, 2022 Report Posted October 11, 2022 Drop a pic of the data you have… Or…. We can go to THE source…. @M20Doc (Mechanical fuel pump for the M20J…) But… Why buy new, when a pump OH may be appropriate? Best regards, -a- Quote
WAFI Posted October 11, 2022 Author Report Posted October 11, 2022 38 minutes ago, carusoam said: Drop a pic of the data you have… Or…. We can go to THE source…. @M20Doc (Mechanical fuel pump for the M20J…) But… Why buy new, when a pump OH may be appropriate? Best regards, -a- Well it looks like a Tempest FP is only around $350 so I figured I go that route but some other part numbers around $600+ Quote
WAFI Posted October 11, 2022 Author Report Posted October 11, 2022 Aircraft Spruce vs Chief Aircraft Looks like a lot of different compatibilities @carusoam@M20Doc Quote
Greg Ellis Posted October 11, 2022 Report Posted October 11, 2022 4 hours ago, WAFI said: Looking for some help regarding witch engine drive fuel Thinking about Halloween, are we... Quote
Guest Posted October 11, 2022 Report Posted October 11, 2022 3 hours ago, WAFI said: Found more info: Make sure it comes with a new gasket, as well as a pair of MS29512-6 “0” rings Quote
WAFI Posted October 11, 2022 Author Report Posted October 11, 2022 53 minutes ago, Greg Ellis said: Thinking about Halloween, are we... Actually yes, just few up to Halloween Horror nights in Orlando… LOL Quote
WAFI Posted October 11, 2022 Author Report Posted October 11, 2022 16 minutes ago, M20Doc said: Make sure it comes with a new gasket, as well as a pair of MS29512-6 “0” rings Copy that… thanks!!! Quote
