Jpravi8tor Posted September 22, 2022 Report Posted September 22, 2022 Does anyone have an ICA for the RSA injector body? what products do you use to clean the inlet?
N201MKTurbo Posted September 22, 2022 Report Posted September 22, 2022 I imagine you mean RSA. There is a thread about that right now, you should check it out.
Jpravi8tor Posted September 22, 2022 Author Report Posted September 22, 2022 Yes I meant RSA where would that thread be?
Jpravi8tor Posted September 22, 2022 Author Report Posted September 22, 2022 I want to clean the throttle plate and throttle body ie.impact tubes not the injectors
PT20J Posted September 23, 2022 Report Posted September 23, 2022 I cannot imagine why you would need to clean the throttle plate or the impact tubes. Cleaning the impact tubes could be especially problematic because any foreign material introduced into them would likely affect the fuel metering. Precision Airmotive https://precisionairmotive.com/ has the service documents on its website. 1
carusoam Posted September 23, 2022 Report Posted September 23, 2022 2 hours ago, Jpravi8tor said: Yes I meant RSA where would that thread be? See if you can find the edit button… It is in the original post… at the top right…. Three dots like ‘…’ is a menu… I skipped by quickly, because I thought we were discussing a different controller… one I’m not familiar with… Best regards, -a- 1
