cferr59 Posted June 14, 2022 Report Posted June 14, 2022 7 hours ago, Jpravi8tor said: Clarence, thank you for your continued interest. I have been studying the parker stratoflex manuals and still cant come up with a size for that hose (assuming the 530 is a size?) Funny thing the lycoming ipc doesnt show oil cooler p/b's because its an airframe part Hose is Stratoflex 111-8 on an M20C. It is probably the same on an F model. As far as producing the hose, does anyone have thoughts on the hoses as an owner produced part: From AC-20-62E: "Parts produced by an owner or operator for maintaining or altering their own product and which are shown to conform to FAA-approved data. " I imagine there is some kind of pressure test that needs to be done, but I would think that applies to hoses produced by an A&P too. Also, my understanding is that the oil cooler hoses are only under pressure when the vernatherm is open so a standard run-up may not find leaks. I just changed the oil cooler hoses with hoses from PHT (I do not know enough to make the hoses and was not sure of the legality) and ended up doing a test flight near the airport until the engine had warmed up enough to open the vernatherm. Quote
EricJ Posted June 14, 2022 Report Posted June 14, 2022 (edited) 59 minutes ago, cferr59 said: Hose is Stratoflex 111-8 on an M20C. It is probably the same on an F model. As far as producing the hose, does anyone have thoughts on the hoses as an owner produced part: From AC-20-62E: "Parts produced by an owner or operator for maintaining or altering their own product and which are shown to conform to FAA-approved data. " I imagine there is some kind of pressure test that needs to be done, but I would think that applies to hoses produced by an A&P too. Also, my understanding is that the oil cooler hoses are only under pressure when the vernatherm is open so a standard run-up may not find leaks. I just changed the oil cooler hoses with hoses from PHT (I do not know enough to make the hoses and was not sure of the legality) and ended up doing a test flight near the airport until the engine had warmed up enough to open the vernatherm. As long as it is not a hydraulic line, hose connections can be replaced under owner maintenance, as can pre-fabbed fuel lines. An A&P can "supervise" you to do nearly anything an A&P can do, which includes fabricating hoses. If you want to do it yourself there's certainly a way to get there from here. Talk to your A&P/IA about what they're comfortable with. Making hoses isn't hard, but don't be sloppy, learn the procedure, and use the right tools. Edit: Even if you do OPP, an A&P has to determine its airworthiness and install it, so it's not going to be much/any different than just making the hose under "supervision", which an A&P can do. OPP is better for things that an A&P is not allow to make/fabricate, which covers a lot of stuff. Edited June 14, 2022 by EricJ 1 Quote
