Yourpilotincommand Posted December 23, 2021 Report Posted December 23, 2021 Not sure if I posted this here, but feel free to comment.. enjoy! 3 1 Quote
N201MKTurbo Posted December 23, 2021 Report Posted December 23, 2021 To remove the cotter pin, just snip it in the middle and all the pieces will just fall out. You don't have to remove the gear door links to get to the brakes. I always talc the inside of the tire instead of the tube. It makes less mess. I use a piece of cardboard if I'm working on the floor, or I work on a wooden bench. Did you repack the bearings before you put them back on? 3 Quote
Yourpilotincommand Posted January 15, 2022 Author Report Posted January 15, 2022 There was no way to remove the caliper bolts unless I removed the gear door link. Quote
N201MKTurbo Posted January 15, 2022 Report Posted January 15, 2022 59 minutes ago, Yourpilotincommand said: There was no way to remove the caliper bolts unless I removed the gear door link. I’ve never had that issue, besides you don’t have to remove the bolts, just the inner plate. Quote
RobertGary1 Posted April 2, 2022 Report Posted April 2, 2022 On 1/15/2022 at 12:24 PM, Yourpilotincommand said: There was no way to remove the caliper bolts unless I removed the gear door link. I’ve never removed the gear door. I have heard other pilots say that but not sure why. Quote
RobertGary1 Posted April 2, 2022 Report Posted April 2, 2022 8 hours ago, RobertGary1 said: I’ve never removed the gear door. I have heard other pilots say that but not sure why. Thinking about it a bit. I don’t remove the bolts until I remove the caliper. I just pull the bolts back enough that the caliper can be freed and then pull it out with the bolts. 1 Quote
