Henk Werner Posted August 3, 2021 Report Posted August 3, 2021 Hi, I have a problem with the AP 150 KFC. during use, when I use the CWS, the AP does not come back to pitch mode, Heading mode does come back. Resetting in flight doesn't help and after parking and a few hours it's back to normal until I use the CWS again. Does anyone have an idea where to look. Regards, Henk Quote
kortopates Posted August 3, 2021 Report Posted August 3, 2021 (edited) What does "when I use the CWS, the AP does not come back to pitch mode" this mean? If the ALT button is not on, the AP should retain the pitch of when you released the CWS button. The CWS is most commonly used to change the pitch quickly/easily. It certainly won't recall where pitch was before you last pressed CWS and go back to it if that's what was expected. A rare M20L in Germany - nice! Edited August 3, 2021 by kortopates Quote
Henk Werner Posted August 3, 2021 Author Report Posted August 3, 2021 I mean when I disconnect the roll servo, the pitch servo and the trim servo with the cws button, only the roll servo connect again when I released the cws button. The M20L is in the Netherlands, German registered Quote
kortopates Posted August 4, 2021 Report Posted August 4, 2021 suggest you talk to Bob Weber - he’s on here.Sent from my iPhone using Tapatalk 1 Quote
carusoam Posted August 5, 2021 Report Posted August 5, 2021 @Henk Werner meet @Bob Weber Mr. Werner has an AP challenge… Mr. Weber has a bank of AP challenge solutions…. Best regards, -a- 1 Quote
