DGates Posted May 8, 2021 Report Posted May 8, 2021 Considering a GI-275 install, which would mean that I no longer need a vacuum system perhaps? My 1965 M20C has the Brittian wing leveler (not the autopilot). Is it "legal" to delete the pump and the associated hardware? I have the vacuum powered step retract, I assume that it could be bolted in the down position somehow. Remove the wing aileron vacuum servos? The TC and the other stuff in the tail cone? Minor mod? Quote
OR75 Posted May 9, 2021 Report Posted May 9, 2021 2A3_Rev_58.pdf see note 24 in the last but one page. That gives you the basis for being able to remove the vacuum system. Quote
Skates97 Posted May 9, 2021 Report Posted May 9, 2021 6 hours ago, bluehighwayflyer said: There is also an electric step conversion kit available if you want to preserve that functionality. @takair makes the step, it's a simple install and we'll worth it. http://www.flightenhancements.com 4 Quote
carusoam Posted May 9, 2021 Report Posted May 9, 2021 Dump the pump! There is a way to do this legally... It always depends on what is being removed, what instruments and devices that are depending on the vac system.... If something is documented as required for flight.... things can get more challenging... Besides instruments... There are vac powered systems like the retractable step... and speed brakes... Each instrument needs a back-up... these are often defined and updated by the company that builds the instrument you are installing... New instruments like the GI275 have their documents updated constantly as big G completes testing and adds things to the list of back-ups.... PP thoughts only, not an instrument guru... Best regards, -a- Quote
cliffy Posted May 11, 2021 Report Posted May 11, 2021 Leaving the rear step out will cost you some speed (a few knots) and a little rumble from drag. Get the electric step! 1 Quote
