Alan Maurer Posted November 16 Report Posted November 16 Using G1000 and it tries to download on MFD...always fails and while it is trying to download cannot continue putting information in to MFD. and we are MAC people so no luck there Alan
LANCECASPER Posted November 16 Report Posted November 16 6 hours ago, Alan Maurer said: Using G1000 and it tries to download on MFD...always fails and while it is trying to download cannot continue putting information in to MFD. and we are MAC people so no luck there Alan Other Mac users have had success:
Jeff_S Posted November 18 Author Report Posted November 18 I realize I never closed the loop on this. When I went back with the second set of downloaded files from Garmin, the mag var update went just fine. You do have to let the PFD reboot, and then run through the actual file updating process, but you eventually get the message shown in the Service Alert document that everything is fine. And it is! 1
Healthpilot Posted November 24 Report Posted November 24 On 11/18/2025 at 11:22 AM, Jeff_S said: I realize I never closed the loop on this. When I went back with the second set of downloaded files from Garmin, the mag var update went just fine. You do have to let the PFD reboot, and then run through the actual file updating process, but you eventually get the message shown in the Service Alert document that everything is fine. And it is! Did you have to use a 2GB SD Card formatted FAT?
Yariv Posted November 24 Report Posted November 24 I realize the question is not directed to me but since I had to go through two tries I can help. In my second try the only thing I changed was the SD card - i went from a 4GB to 2GB. The new 2GB card came formatted as FAT. I had to reformat it as FAT32. The CB that I pulled was GPS2. Good luck. Yariv 1
Healthpilot Posted December 2 Report Posted December 2 On 11/24/2025 at 3:59 PM, Yariv said: I realize the question is not directed to me but since I had to go through two tries I can help. In my second try the only thing I changed was the SD card - i went from a 4GB to 2GB. The new 2GB card came formatted as FAT. I had to reformat it as FAT32. The CB that I pulled was GPS2. Good luck. Yariv Hi Yariv, Thank you for your input. I called Garmin and I formatted FAT and it worked. I had to use a 2GB card (must be max 2GB they said) and it worked like a charm. I pulled CB for NAV2 and COM2 both. They whole update completed in less than 4 min. Hope you are well! Davide 1
