Chris newton Posted September 22, 2019 Report Posted September 22, 2019 (edited) I have a 1989 M20 j 201 .i am looking for the clear lens and bulb that is on the trailing edge of the wingtip. Any ideas? Edited September 22, 2019 by Chris newton
Yetti Posted September 23, 2019 Report Posted September 23, 2019 http://www.glapinc.com/Mooney/m20j.htm
carusoam Posted September 23, 2019 Report Posted September 23, 2019 Welcome aboard Chris... I think there May be some confusion of what exactly you have in your wing tip... Do you have the nicely molded wing tips with a single white light pointing aft? It really helps to post a pic in this case? It might be a Whelen, Grimes or other brand... One place you can go is called Lasar.com speak with Dan in parts... give him the same detail you gave here. Best regards, -a-
Steve W Posted September 23, 2019 Report Posted September 23, 2019 Probably need a photo or a serial number. If it's the enclosed wingtip there are at least 3 different bulbs depending on if it's 12 or 24V and if it's been converted from the bi-pin to the wedge base, if it hasn't been converted it may be worth it. Luckily the cover(which is glass, since it's a tiny assembly and those stupid bulbs get HOT) only looks to be about $130. (68-4250066-30)
