Oscar Avalle Posted July 27, 2019 Report Posted July 27, 2019 I am looking for the calibration instructions for my ASPEN AOA. The dealer provided them to me, but unfortunately I misplaced them. So if anybody can help me... thank you
Oldguy Posted August 5, 2019 Report Posted August 5, 2019 On 7/27/2019 at 6:51 PM, Oscar Avalle said: I am looking for the calibration instructions for my ASPEN AOA. The dealer provided them to me, but unfortunately I misplaced them. So if anybody can help me... thank you Oscar, Did you ever have any luck? If not, here is what I have. Insert other media Aspen AOA Calibration Procedure.pdf
Oscar Avalle Posted August 5, 2019 Author Report Posted August 5, 2019 Oscar, Did you ever have any luck? If not, here is what I have.Insert other media Aspen AOA Calibration Procedure.pdf Not yet, thank you!!!Sent from my iPhone using Tapatalk Pro
Stanton R Posted August 8, 2019 Report Posted August 8, 2019 From personal experience go on a calm smooth day. It is very hard to keep the required speeds, heading and altitude required to complete the calibration. I also seems to work best if you are close to max weight. Also bring someone along to keep an eye out for traffic you will be spending several minutes watching instruments.
jetdriven Posted August 9, 2019 Report Posted August 9, 2019 Do you calibrate it with flaps up or flaps down?. The question I have is if it’s calibrated with the flaps up how do you know what the real stall speed is with flaps down?
PT20J Posted August 9, 2019 Report Posted August 9, 2019 (edited) 2 hours ago, jetdriven said: Do you calibrate it with flaps up or flaps down?. The question I have is if it’s calibrated with the flaps up how do you know what the real stall speed is with flaps down? The procedure calls for calibration both clean and flaps/gear down. There are two pointers, one for each calibration setting. Mine (installed by a defunct avionics shop for the previous owner) is way out of calibration; normal approach is way into the cross-hatch stall warning area. Sooner or later I will try to correct it, but the display on a single display EFD1000 is so small that it doesn't really seem that useful to me. Skip Edited August 9, 2019 by PT20J
Oscar Avalle Posted August 12, 2019 Author Report Posted August 12, 2019 Thanks for sharing the instructions with me. The procedure is easy and well explained. I calibrated the indicator today. However, I have to admit the indicator in a PFD is rather small. So it is not very user-friendly and easy to read. But it is useful once you get used to it.
Tyler G Posted March 3, 2025 Report Posted March 3, 2025 What speeds did you use for the AOA calibration? AOA Calibration Min Vis AOA 1.5 x VSO (100 KIAS) Stall Warning AOA at Stall Caution Alert AOA 1.1 x VSO (Stall + 5 KIAS) Approach Target AOA 1.3 x VSO (500FPM Short Final Speed 75 KIAS)
