I will be starting the IR flight training Wednesday and I am really looking forward to it.  Any advice from any J pilots.  Any standards re power settings and AI indications for climbs, descents and turns?  Curious how my AC compares to similar Js.
you'll find all the right power settings for your plane in no time or you should go experiment in VFR some day. Good luck with the training - it will be very rewarding :)
Apart from the normal training make sure you know how to make quick descents or to scrub speed quickly - had a couple of times where I was told to keep my speed up on approach. Have your instructor give you such instructions on random approaches and see how you do at "abnormal" speeds and power settings - or have more than 1 ballpark approach power settings.
Also forgot to lower the gear once on approach when the instructor overloaded me with "stuff" to do - even after I heard the gear warning horn !! :) (went missed and instructor knew about it - so was not a real issue) My gear warning horn sounds like a series of beeps - wish it shouted "stupid" or something - altho dont know if I would have paid attention to it even then.
bd32322 has it right.  The best thing I did was go out with a buddy and a note pad and set up my power settings for straight and level, descents, with/without flaps, gear out, etc.  PM me and I can shoot you the information that I use for my J.  It will save you a lot of headache and frustration if you get these settings down.
