Magnum Posted June 7, 2011 Report Posted June 7, 2011 Quote: Awful_Charlie If you find FPP crashing, drop Mike a note. He develops on a Mac, so will probably have a fix. Rocketroute uses Mikes routing engine anyway, so you should get the same result without the cost overhead, but will also get the extras like the freezing and cloud profile too. EuroFPL is just a gateway for FPP and other routing engines to the CFMU validator posted above (Avbrief also offers the route suggestion via the same B2B gateway, but doesn't save the info), and saves validated routes, as well as periodically re-validating them. EuroFPL also does the filing and slot/notification management. I was sat in the aircraft on Sunday with lousy weather and filed a flight plan on my Android, and got the ack back in less than a minute. Calling La Rochelle for a start clearance, they hadn't even seen the FPL yet, but they checked and gave me a clearance. Total time from pressing the 'file' button to getting a start was probably less than 3 minutes. I would strongly suggest you join PPLIR Europe, where these sort of problems are regularly discussed and resolved, as well as for the lobbying they do do preserve the rights we currently have. Both Travis and Mike are contributors there, as well as several instructors and examiners, and some with vast amounts of EU IFR experience. Ben Quote
flyboy0681 Posted June 7, 2011 Report Posted June 7, 2011 Quote: Magnum That's what I did, got my CPL/IR in Florida last November. I am just getting used to the system here. Quote
231BB Posted December 3, 2011 Report Posted December 3, 2011 Quote: Magnum "Zuverlässigkeitsüberprüfung" Quote
