HRM Posted May 27, 2018 Report Posted May 27, 2018 12 hours ago, gsxrpilot said: A lot of "anecdotal" negative evidence... Well, I really am not trying to be a pessimist. @StinkBug's C is vinyl striped, not wrapped from what I see. There are two issues here: vinyl striping and vinyl wrapping, the latter is in lieu of a paint job and is a more significant operation with potentially serious consequences. Of course, I suppose a strip of vinyl striping could peel off and cause issues, but I doubt that is going to happen. From what @1964-M20E posted above, it looks like only the control surfaces are best left untouched--that makes good sense, why play with fate? I am going to hunt down that RV accident, I have a suspicion that ailerons got wrapped, not good. Paint is seamless, vinyl is not. Quote
GDGR Posted May 27, 2018 Author Report Posted May 27, 2018 (edited) FWIW, I saw this as a way to make the aircraft a little more “what I want”, without forking out another 15k for paint right off the hop. Also, the A&P performing the prebuy suggested a guy to do the work. I’m 100% certain hes sogn iff on the works at the same time. Edited May 27, 2018 by CDNflyby Quote
kmyfm20s Posted May 28, 2018 Report Posted May 28, 2018 10 hours ago, HRM said: Well, I really am not trying to be a pessimist. @StinkBug's C is vinyl striped, not wrapped from what I see. There are two issues here: vinyl striping and vinyl wrapping, the latter is in lieu of a paint job and is a more significant operation with potentially serious consequences. Of course, I suppose a strip of vinyl striping could peel off and cause issues, but I doubt that is going to happen. From what @1964-M20E posted above, it looks like only the control surfaces are best left untouched--that makes good sense, why play with fate? I am going to hunt down that RV accident, I have a suspicion that ailerons got wrapped, not good. Paint is seamless, vinyl is not. Look at the picture above of @StinkBug‘s plane everything red is wrap. Rudder and ailerones have wrap on them. He has not gone out of control and crashed his plane. I drive by his plane 2X a week and it has no signs of peeling off and it looks great, it works! I have 2 vehicle that I have wrapped. I have held a pressure washer on the wrap and it has not come off or get damaged. 1 Quote
wesley parker Posted May 28, 2018 Report Posted May 28, 2018 I did all the controls on my Zodiac with no negative results. The wrap is incredibly light. Quote
HRM Posted May 29, 2018 Report Posted May 29, 2018 22 hours ago, kmyfm20s said: Look at the picture above of @StinkBug‘s plane everything red is wrap. Rudder and ailerones have wrap on them. He has not gone out of control and crashed his plane. I drive by his plane 2X a week and it has no signs of peeling off and it looks great, it works! I have 2 vehicle that I have wrapped. I have held a pressure washer on the wrap and it has not come off or get damaged. I stand corrected. No biggie, the more I investigate this, the more likely I'll wrap the Mustang. Quote
carusoam Posted May 29, 2018 Report Posted May 29, 2018 Harley, Start with pictures of the Mustang... MS can help you decide on the wrap... Best regards, -a- 1 Quote
HRM Posted June 2, 2018 Report Posted June 2, 2018 On 5/28/2018 at 8:44 PM, carusoam said: Harley, Start with pictures of the Mustang... MS can help you decide on the wrap... Best regards, -a- 2 Quote
RobertGary1 Posted June 5, 2018 Report Posted June 5, 2018 Is the vinyl a moisture barrier? -Robert Quote
steingar Posted June 5, 2018 Report Posted June 5, 2018 I had vinyl stripes on my Cherokee, and I have to admit after ten years they were stating to look a little ratty. That said, these were put on before the modern age of tiny wraps and may be an altogether different material. Quote
