Grandmas Flying Couch Posted April 3, 2018 Report Posted April 3, 2018 I was wondering if any of you had good mixture cable routing, my old mixture cable was routed in such a way that the yoke linkage under the panel pushed on the cable pretty bad, I had a new mixture cable installed and it also Interferes, although routed differently. If anyone has pics, I would really appreciate the help. Quote
carusoam Posted April 4, 2018 Report Posted April 4, 2018 Invite @M20Doc for this question... Mixture cable surprises can be terrible... Best regards, -a- Quote
Grandmas Flying Couch Posted April 4, 2018 Author Report Posted April 4, 2018 33 minutes ago, carusoam said: Invite @M20Doc for this question... Mixture cable surprises can be terrible... Best regards, -a- How do you invite? Thanks! Quote
carusoam Posted April 4, 2018 Report Posted April 4, 2018 Already did... using the @ sign and then spell their screen name... The rest is selecting from the automatic list... They get a notification... like this... @Grandmas Flying Couch See? Notification on you screen @ the top... Best regards, -a- Quote
Grandmas Flying Couch Posted April 4, 2018 Author Report Posted April 4, 2018 Thanks, I get it now! Quote
Andy95W Posted April 4, 2018 Report Posted April 4, 2018 7 hours ago, Grandmas Flying Couch said: I was wondering if any of you had good mixture cable routing, my old mixture cable was routed in such a way that the yoke linkage under the panel pushed on the cable pretty bad, I had a new mixture cable installed and it also Interferes, although routed differently. If anyone has pics, I would really appreciate the help. There's more than one way to skin a cat. The right way is any way that it doesn't interfere with anything else under and behind the panel, particularly the flight controls through their entire range of motion. This issue definitely needs to go back to the installer because it isn't correct and they will know it. They probably won't want to make it right, but they should. I'm sorry this doesn't answer your specific question, but routing cables/lines/wire bundles is a bit of an art form. They don't have to be the same to be acceptable. Quote
Guest Posted April 4, 2018 Report Posted April 4, 2018 It will need to be removed and reinstalled so that it clears all controls and may need additional Adel clamps to hold it secure it correctly. Clarence Quote
Grandmas Flying Couch Posted April 9, 2018 Author Report Posted April 9, 2018 Thanks @M20Doc, I will have it done, unfortunately I'm waiting for new cables for the mixture and prop, I sent pics to McFarlane of the behavior of the two cables, the mixture skips when turning it and the prop cable is bent so that it orbits as you turn the knob. The prop cable has pleir marks on the shaft when you pull the knob that grind inside the mech. McFarlane says they wouldn't trust the cables as the installer has damaged them. Quote
