Northern Mooniac Posted May 15, 2017 Report Posted May 15, 2017 Where can a guy get the buttons fixed? Currently have to press them firmly to get them to work. I have waas already. I was told $1000 for an overhaul to the whole unit?
Lance Keve Posted May 15, 2017 Report Posted May 15, 2017 Hello Northern Mooniac - I've seen others post here that if you repeatedly press a button many many times (100?), it will start to work better. Some of mine are similar to yours and the more I use them, the easier they are to use. Probably some oxidation on contacts that cleans up a bit from repeated contact.
Godfather Posted May 15, 2017 Report Posted May 15, 2017 Garmin previously required all unit to be shipped in with the flat rate fee. Over the past year they changed the rules and you can have it done at a service center.
KSMooniac Posted May 15, 2017 Report Posted May 15, 2017 Garmin previously required all unit to be shipped in with the flat rate fee. Over the past year they changed the rules and you can have it done at a service center. This is true...my local shop fixed my buttons recently when I got a software update. Check with your shop, or send it to mine (Bevan-Rabell in Wichita).Sent from my LG-US996 using Tapatalk
