FlyWalt Posted April 16, 2015 Report Posted April 16, 2015 Good Morning Fellow Mooniacs, I have my avionics guy chasing a Fuel Low light issue in our annunciator panel. They have been intermittently unreliable on the push to test item on the before starting checklist. He has it narrowed down to something faulty in the 37 yr old IC circuits on the board. Picture is attached. Part number is: 500D0038 Does anyone have a solution for this? Thank you in advance, W Quote
dtoelke Posted April 16, 2015 Report Posted April 16, 2015 I have the same issue with mine. Haven't looked into fixing yet. Quote
FlyWalt Posted April 17, 2015 Author Report Posted April 17, 2015 Well I have a new philosophy regarding aircraft maintenance. If it doesn't work or doesn't work as certified., it gets fixed. Period. After 3 years of owning 231LR she is darn near 99.9 percent restored mechanically. I will be posting pics soon after the next Meguiars wax job. :-) Quote
Geoff Posted April 17, 2015 Report Posted April 17, 2015 I had similar problem. First check the bulbs are working by swapping them with others in the annunciator that you know work. If bulbs are ok then your only choice is to send annunciator panel to IA in Dallas. Cost will be about 1.6 AMUs for a rebuild and they will rebuild the whole thing. They did mine and it is perfect and it took about a week. Now before you worry about the cost, you should know that two years ago IA tried to sell this part of their business without success and almost shut it down which would have left us all in a real mess. Hope this helps. Quote
ArtVandelay Posted April 17, 2015 Report Posted April 17, 2015 Does anybody have a schematic for it? Quote
FlyWalt Posted April 17, 2015 Author Report Posted April 17, 2015 It is in the electrical section of your maintenance manual. And on that note, I have narrowed it down to two parts thanks to an excellent job of writing by Mooney on that manual. Question, does anyone have a pdf of the maintenance manual for the earlier 231s? I have the manual for the later models and I need one that covers serial no 25-0025. Thanks, Walt Quote
Guillaume Posted April 19, 2015 Report Posted April 19, 2015 Service and maintenance manual are not serial number specific. For the M20K you should use MAN134 (latest revision 3-00) regardless of your s/n. The manual contains the differences between the early models and the late models. Quote
mooney2201 Posted April 19, 2015 Report Posted April 19, 2015 any electronics shop can fix this unit...very simple....they can shotgun the unit and find most of the time its a bad transistor..only a couple of ttl,s can get all parts on ebay...SIMPLE FIX Quote
FlyWalt Posted April 20, 2015 Author Report Posted April 20, 2015 Any decent ham radio operator could fix this box. Quote
ArtVandelay Posted April 20, 2015 Report Posted April 20, 2015 any electronics shop can fix this unit...very simple....they can shotgun the unit and find most of the time its a bad transistor..only a couple of ttl,s can get all parts on ebay...SIMPLE FIX Could be a capacitor as well, they can be checked with a fluke meter. Quote
Jimhamilton Posted April 20, 2015 Report Posted April 20, 2015 I had similar problem. First check the bulbs are working by swapping them with others in the annunciator that you know work. If bulbs are ok then your only choice is to send annunciator panel to IA in Dallas. Cost will be about 1.6 AMUs for a rebuild and they will rebuild the whole thing. They did mine and it is perfect and it took about a week. Now before you worry about the cost, you should know that two years ago IA tried to sell this part of their business without success and almost shut it down which would have left us all in a real mess. Hope this helps. OK, so what is 1.6 AMUs exactly. Shop hours?, Price in gold? Just wondering. Quote
carusoam Posted April 20, 2015 Report Posted April 20, 2015 Exactly 1.6k. Or 1.6M, expressed in USD, depending on your finance administrator... -a- Quote
ArtVandelay Posted April 20, 2015 Report Posted April 20, 2015 It is in the electrical section of your maintenance manual. And on that note, I have narrowed it down to two parts thanks to an excellent job of writing by Mooney on that manual. Question, does anyone have a pdf of the maintenance manual for the earlier 231s? I have the manual for the later models and I need one that covers serial no 25-0025. Thanks, Walt The version I have only includes wiring diagrams, the manual refers to separate drawings, but does include a nice troubleshooting section 24-39-05, unfortunately without corresponding drawings might be problematic. Quote
Jimhamilton Posted April 21, 2015 Report Posted April 21, 2015 Exactly 1.6k. Or 1.6M, expressed in USD, depending on your finance administrator... -a- OK, I am guessing the repair would be about $1,600.00 US dollars. If I have converted it right. Thanks. 1 Quote
FlyWalt Posted April 22, 2015 Author Report Posted April 22, 2015 OK, I am guessing the repair would be about $1,600.00 US dollars. If I have converted it right. Thanks. Yet the two parts that I found to be bad are about 88 cents at any electronic supply shop. Amazing how many "Aviation Businesses" make their way by ripping us off. And they wonder why aviation is in decline. Trust me, it is not just the government nor fuel prices that are to blame. 1 Quote
Jimhamilton Posted April 23, 2015 Report Posted April 23, 2015 Yet the two parts that I found to be bad are about 88 cents at any electronic supply shop. Amazing how many "Aviation Businesses" make their way by ripping us off. And they wonder why aviation is in decline. Trust me, it is not just the government nor fuel prices that are to blame. So, can you take a pic or describe how you fixed it for the rest of us. Please, this just may come in handy. Quote
dtoelke Posted April 23, 2015 Report Posted April 23, 2015 So, can you take a pic or describe how you fixed it for the rest of us. Please, this just may come in handy. Yes I'd also be very interested to see this. 1 Quote
FlyWalt Posted April 23, 2015 Author Report Posted April 23, 2015 Gentlemen, In the electrical section of the 231 maintenance manual there is a troubleshooting list that describes all the possible symptoms and the associated parts on the schematic that if bad would cause said symptoms. It takes some digging and reading, but all of the information is there. As a ham radio operator I can say that the schematic is very well laid out. Hope this helps, W Quote
Jimhamilton Posted April 24, 2015 Report Posted April 24, 2015 Mooney MX Manual 24-39-05 is where you want to start. The schematics follow a few pages later. So.....there you have it. Good Luck and good hunting for those of us, including myself, that are a little challenged in this area. Quote
ArtVandelay Posted April 24, 2015 Report Posted April 24, 2015 Mooney MX Manual 24-39-05 is where you want to start. The schematics follow a few pages later. So.....there you have it. Good Luck and good hunting for those of us, including myself, that are a little challenged in this area. I believe the next section schematics apply to the late models, the 28V systems, the only doc on the older versions is in service instruction 74. 1 Quote
Jimhamilton Posted April 24, 2015 Report Posted April 24, 2015 I believe the next section schematics apply to the late models, the 28V systems, the only doc on the older versions is in service instruction 74. Yes, you are right. You can find this service instruction 74 on the Mooney website. Go to Service and Support then click on Service Instructions and then M20K. The service instructions are in numerical order. Look for 74. Looks like a simple fix. Quote
dtoelke Posted April 24, 2015 Report Posted April 24, 2015 Yes, you are right. You can find this service instruction 74 on the Mooney website. Go to Service and Support then click on Service Instructions and then M20K. The service instructions are in numerical order. Look for 74. Looks like a simple fix. Looks easy enough. I'm having a hard time finding that part number though. Does somebody have a P/N for the equivalent at Radio Shack? Quote
dtoelke Posted April 24, 2015 Report Posted April 24, 2015 Nvm I'm just going to go pull it and stop by the local avionics shop which should have them. Does anyone else with this issue also have the same issue with the "alt air" light? Quote
Jimhamilton Posted April 25, 2015 Report Posted April 25, 2015 Looks easy enough. I'm having a hard time finding that part number though. Does somebody have a P/N for the equivalent at Radio Shack? Radio Shack? They still in business? Quote
dtoelke Posted May 2, 2015 Report Posted May 2, 2015 I pulled the annunciator panel yesterday and opened it up. Low and behold the circuit layout is completely different than the one shown in the service instruction. I could only find two 100K resistors on the board so I'd assume they are the ones in question but I want to confirm before replacing. Has anybody else ran into this issue? I've confirmed the SI applies to my S/N and the annunciator box is original equipment (shipped date Feb 1979) Quote
