helitim Posted November 3, 2014 Report Posted November 3, 2014 According to my POH, "A reduced fuel quantity indicator is installed in each tank. These indicators show the 25 U.S. gallon usable fuel level in each tank." What exactly does this mean? Does it mean the fuel indicator shows the last 25 usable gallons and not the first 7 or, the other way around? The POH gives no other information on this subject. Total capacity is 66.5 with 64 usable. Quote
carusoam Posted November 3, 2014 Report Posted November 3, 2014 Tim, What year does your POH come from? Best regards, -a- Quote
helitim Posted November 3, 2014 Author Report Posted November 3, 2014 The aircraft is a 77'. The POH says it was issued 9-27-76 Quote
aaronk25 Posted November 3, 2014 Report Posted November 3, 2014 Does it have bladders? Is it a insert from a stc? I have a 77' J and my total is also advertised as 66.5, with 64 usable. In level flight each tank has 33 gallons of usable, but if one is close to running out as soon as a decent is started fuel runs forward engine goes cold.... Not sure on 50 gallons..... Quote
carusoam Posted November 3, 2014 Report Posted November 3, 2014 Reduced fuel quantity sounds like fuel used. Does it somehow count backwards? Best regards, -a- Quote
helitim Posted November 3, 2014 Author Report Posted November 3, 2014 I attached a copy of the POH page. Maybe it will make sense to one of you? Quote
helitim Posted November 3, 2014 Author Report Posted November 3, 2014 No bladders installed. The fuel gauge appears to be a standard gauge. No countdown device that I am aware of. Quote
jetdriven Posted November 3, 2014 Report Posted November 3, 2014 I think It's a tab like Cherokees have that shows a lesser fuel quantity. That said I have never seen one on a Mooney. Quote
Cruiser Posted November 3, 2014 Report Posted November 3, 2014 Byron is correct. There is a metal tab that extends into the tank at the filler. Filling to the bottom of the tab is the 25 gallon indicator. Quote
helitim Posted November 3, 2014 Author Report Posted November 3, 2014 Yes, I have noticed the tabs in the tanks. Had no idea this is what was being referred to in the POH. Thank you Byron/TomK Quote
aaronk25 Posted November 3, 2014 Report Posted November 3, 2014 Oh....duh...my J has those metal tabs indicating the 25gallon usable mark... Quote
AlanA Posted November 3, 2014 Report Posted November 3, 2014 The linemen at the airports are familiar with these tabs. Just tell them to "fill it to the tabs" and they will fill it until the fuel is just touching the bottom of that metal tab in the fuel tank. Now you have 50 gallons. 1 Quote
jetdriven Posted November 3, 2014 Report Posted November 3, 2014 I have the 54 gallon bladders. When u fill it to the tabs for 25 gal a side it's the tab that locks the fuel filler cap. Quote
helitim Posted November 3, 2014 Author Report Posted November 3, 2014 The way the POH described it, I guess I was expecting something different than fill tabs. Learn something every day. Thanks again. Quote
N201MKTurbo Posted November 3, 2014 Report Posted November 3, 2014 Just fill it till the fuel is up to the little hole then stop the pump, it'll settle to the bottom of the tab. 1 Quote
Cruiser Posted November 3, 2014 Report Posted November 3, 2014 On the North Slope, Pruhdoe Bay oil fields facility has an indoor swimming pool. Of course it's official name is the Fire Prevention reserve water supply, I guess it's all in how you read the words. Quote
