Dcflyn Posted October 9, 2014 Report Posted October 9, 2014 We're putting the final touches on our interior reburbishment of our M20E. I'm replacing the airspeed placard, but it wasn't filled out before. Who can help me fill it out with the proper numbers? Keep in mind I have zero hours as PIC. Getting ready to start my 15 hours of dual. http://n2690w.blogspot.com/ Thanks, David Slowest descent power off: Most flight time per gallon of fuel: Steepest climb: Best rate of climb 5,000 to 10,000 FT.: Shallowest glide: Best rate of climb 0 to 5,000 FT.: Most miles per gallon of fuel: Ecomomy cruising: Normal cruising: Quote
DS1980 Posted October 9, 2014 Report Posted October 9, 2014 This is a very odd card. Anyone else have this card? As far as the numbers are concerned, I would give you homework and find them in the performance section. You won't find most miles per gallon of fuel in the POH. You will have to ask Bernard Carson. Quote
MB65E Posted October 9, 2014 Report Posted October 9, 2014 Never seen that placard either...but good stuff. My guess is it's not a required one in the POH. I would refrance the POH for the numbers it lists, and then during your training try and see what your numbers in question are. Each airplane will be slightly different. Enjoy your airplane, all the hard work will soon pay off... Right after the mains kiss the ground again!! Nice Work! -Matt Quote
Hank Posted October 10, 2014 Report Posted October 10, 2014 Best rate of climb is at Vy, which is altitude dependent. In my C, it's (100 MPH - altitude in thousands), and the rate of climb decreases with altitude. You can probably pick so number on the VSI to hold and get decent performance, but it's not how our planes were designed. Same for cruise power settings, very altitude dependent. Longest duration per the Oeners Manual, or longest duration per Vz, Catson's Speed? Both are too slow for my taste, the controls are too mushy. Please try it after you get used to the feel of normal cruise and see for yourself. When descending, I keep power on to salvage potential energy (altitude becomes speed) and make up for the slow climb. Welcome to the Mooney world! Get ready to have lots of fun! Quote
carusoam Posted October 10, 2014 Report Posted October 10, 2014 MAPA produces a book of all Mooney speeds. It's included with the training. Do you have a POH? Mooney POHs were developed over the years. The best ones for the C (probably E as well) were last printed for the 1977 model. Best regards, -a- Quote
Dcflyn Posted October 10, 2014 Author Report Posted October 10, 2014 Yes, I have the original POH, but it doesn't have many of these V-numbers. Though it was a metal placard, maybe it was designed by the previous owner. Thanks for the suggestions. I definitely need to get involved with MAPA. Sent from my iPad using Tapatalk 1 Quote
MB65E Posted October 10, 2014 Report Posted October 10, 2014 Check this link out DC! Lots of great info about the M20's from MAPA. http://72.10.105.106/tms/misc/MAPAMooneyManual.pdf Best, -Matt Quote
MooneyPTG Posted October 23, 2014 Report Posted October 23, 2014 Dave I have my 74E POH as a PDF. If you give me your email I will send. It is too big to post on mooney space. Quote
Dcflyn Posted October 23, 2014 Author Report Posted October 23, 2014 PTG, you da man! Thank you very much. I'm also slogging through the MAPA Bible. Dcflyn@gmail.com Sent from my iPad using Tapatalk Quote
