Marauder Posted November 22, 2014 Report Posted November 22, 2014 Don -- not really sure what is going on with your plane. There are a number of planes in my hangar that fly infrequently and most are using Concordes. Some have chargers on them, others just sit. When I talk to the owners, I don't get a sense they are dealing with dead batteries. If you have the Batteryminderm designed for Concordes, it is a set and forget device. I have one and if I won't fly for a week or so -- and I know it, I will hook it up and do its thing. The Batteryminder also has a built in tester (I believe) to verify that it is hooked up correctly and that the battery is healthy. I would pull the battery, bring it home and hook it up to charge. The documentation for the unit should verify what it wiil or won't do. I will see if I can find a version online.
Marauder Posted November 22, 2014 Report Posted November 22, 2014 Don -- if you have the BatteryMinder designed for the Concorde, it is a "plug and forget" device capable of checking the status of the battery. http://www.concordebattery.com/accessories.php?id=62 One thing you may have going on is some draw that is playing a role. Concorde sells a parasite draw tester to see if this is the case. Might want to invest in one to test your plane. http://www.concordebattery.com/accessories.php?id=64
N601RX Posted November 22, 2014 Report Posted November 22, 2014 The Concorde RG batteries have a very low self discharge rate. In cold weather it is almost nonexistent, and still low in hot weather. Assuming you alternator is fully charging the battery there shouldn't be a problem with it sitting between flights. These discharge at a rate of around 3% per month and the rate remains constant over the life of the battery. By comparison a lead acid battery will discharge at a rate of up to 10% per month when new and the rate will increase as it gets older. Anything up 10% discharge is considered a shallow discharge, anything over 50% discharge is considered a deep discharge and should be recharged immediately to prevent long term life loss.
DonMuncy Posted November 22, 2014 Author Report Posted November 22, 2014 For those of you using the BM with the temperature sensor, where does it sense from. I have the BM plugged into a wall receptacle with wires run over to the Oxygen door on the plane and through to the battery posts. Would this set-up work with the temperature sensing device.
DonMuncy Posted November 22, 2014 Author Report Posted November 22, 2014 You may be right Jim. In aviation, as in life, there are many situations which are not very susceptible to exact or even very good answers. I just try to do the best I can to extend the usefulness and life of $300 batteries. And so far, I'm not doing too well
jetdriven Posted November 22, 2014 Report Posted November 22, 2014 106$ right now, but yeah they were 89$ a few months ago. http://www.skygeek.com/j11968-14.html
DonMuncy Posted November 22, 2014 Author Report Posted November 22, 2014 Just under $300. Aircraft Spruce has them with free shipping. I went ahead and got mine locally. I'm always torn as I like to support both my local Falcon Crest dealer and Aircraft Spruce.
