moodychief Posted February 16, 2014 Report Posted February 16, 2014 Mooneyspace saved my airplane. After reading several entries discussing the gear lock mechanism on the vintage Mooney's I decided to check mine. After looking at the worn areas on the old gear lock I wasn't going to take any chances. I noticed a little play in the Johnson bar when checking the gear down so I immediately ordered and had my mechanic install a new LASAR gear lock. 2 Quote
Sabremech Posted February 16, 2014 Report Posted February 16, 2014 Did mine last year as it was worn more than yours is. I also did the up lock so that the gear handle was tight in both positions. David Quote
scottfromiowa Posted February 16, 2014 Report Posted February 16, 2014 What are hours on your airframes? Quote
moodychief Posted February 16, 2014 Author Report Posted February 16, 2014 2600 TT, rolled off assembly line November 1962 Quote
Sabremech Posted February 26, 2014 Report Posted February 26, 2014 Here's mine from a year ago. Just a little wear from 7600 Hours and countless landings. David Quote
orionflt Posted February 26, 2014 Report Posted February 26, 2014 Just took a look at mine after a little over 4000 hour on my 62C. Surprisingly there was almost no wear and I confirmed it is still original. Quote
Jerry 5TJ Posted February 27, 2014 Report Posted February 27, 2014 I replaced the "C" bird's uplock block in 2009. It had ~3900 hours on it and was worn to about the state that Sabremech photographed. Easy job to replace it. Anyone who wants the old one send me a PM. Quote
