Hello,
Does anyone have any suggestions how I can tell what brakes my 1965 M20E Super 21 has. I normally order everything from LASAR but they are closed until January 2nd. I would like to order from Aircraft Spruce but they are asking brake system type (example-Clevland brakes).  I need linings, rivits, and caliper O-rings-rebuild kits. I would like to order the parts on 12/23/13. Any help would be greatly appreciated.
Thanks,
Mitch
Last annual we replaced the caliper o-rings (parker MS 28775-326) and the brake linings (066-11100).  The brake lining part number is from Linda Lou but probably corresponds to that at Aircraft Spruce.  Also replaced discs because of low thichness as miked.  As I recall Aircraft Spruce (or Cleveland) web-site has a model specific pull down list giving part numbers.
Steve65E-NC
Steve65E-NC
I bought mine from spruce, too.  I have a C, but they are probably the same.  I still have the part # in my flight bag if the website doesn't list it.  Remember that you need 4.  I had a brain fart and ordered only 2.
Steve65E-NC,
Thank you so much for the accurate information. I ordered the linings and O-rings for the calipers from Aircraft Spruce with the numbers you posted. They were exact matches. Had them installed and bled the brakes and everything works great.
Thanks again,
Mitch
