I'm new to this site so it might take me a while to get used to it. I joined so I could put my Mooney up for sale.
1971 M20 F Executive for sale. Registration N6797V. Serial Number 700069. ACTT 2912 Lycoming I0 360 A1A 472 SMOH Overhaul was done by a local mechanic in 2003. STC 3 blade Hartzell prop.
Full IFR. Garmin 430, KX 155 Nav com, Accu track auto pilot. Pilot PTT with 4 place intercom, Standby vacuum, M20 air/oil seperator.
Just got done with annual inspection next due 11/13. IFR check due 9/13.New tires New battery, new spark plugs, new tach, new turn cooridinator ,new horizon. Compressions were all 75 and higher. Tanks have been resealed last annual.
This Mooney had a gear up landing a year ago. I purchased it in March from insurance salvage. Replaced 4 belly skins and front gear doors and replaced the prop with 192 hr prop. I,v put 60 to 70 hrs on since then.
My mechanic speaks highly of this airplane. If you want to speak with my mechanic about it call Travis Pritchett (573 578 5188)
Very nice leather seats. Carpet is nice except for an old fuel stain under the back seat. Paint shines really well and looks good except for a few runs. Some chips in the front of the cowling. Really a nice clean and solid airplane.
55K OBO. Call Rich Miller 573 619 4084.post-10771-0-22641600-1352862356_thumb.jpost-10771-0-17323400-1352862398_thumb.jpost-10771-0-82624000-1352862458_thumb.jpost-10771-0-98799300-1352862508_thumb.jpost-10771-0-58239400-1352862597_thumb.jpost-10771-0-82679100-1352862642_thumb.jpost-10771-0-51032800-1352862696_thumb.jpost-10771-0-36325100-1352862762_thumb.jpost-10771-0-08985700-1352862799_thumb.j
post-10771-0-32497900-1352863112_thumb.j
I believe the serial numbers from that era of Mooney consisted of the first two digits being the year, followed by the production sequence number, so this would have been the 69th plane made in 1970. Was the engine IRANed following the gear up?
My mistake. It is a 1970. I checked on the airworthiness certificate. It was issued in 1970.
My local mechanic did the prop strike inspection. And yeah we did the cheap inspection. We dialed the crank, sent the gears off for die glow inspection and replaced the tab and the bolt. 2 to 3 inches of each prop blade was curled inward. I talked to quit a few different mechanics and they all believed this engine wasnt hurt.
I bought this plane to fly for a year or so with the intention to sell it. Im in partnership with my brother on this plane. If I cant sell it I'll have to buy my brothers share and try to swing it. But I'm really not in a financal position to do that.
  • 2 weeks later...
The prop strike inspection is not the "Cheap" one , It is what Lycoming requires for an inspection, It is adequate , and correct....
Thank you. I apreciate your comments. I was told that almost all insurance copmanies will cover this type of prop strike inspection.
However there are those who almost make you feel like a criminal if you dont tear the engine completly down and basically overhaul the engine after a prop strike. Even after a (quote) light prop strike.
  • Members Online
