Tommooney Posted October 14, 2025 Report Posted October 14, 2025 I am looking for replacement static wicks. I ordered from Spruce and they came 6' long. The originals are 4" long. Suggestions appreciated.
Marc_B Posted October 14, 2025 Report Posted October 14, 2025 @Tommooney best price I've found: https://www.scross.com/store/part-number?10-900-60-1 1
Slick Nick Posted October 14, 2025 Report Posted October 14, 2025 I got some replacements from LASAR. 1
Buckster Posted December 7, 2025 Report Posted December 7, 2025 Last time I looked for a replacement they were sold out. I took the broken one and used epoxy and then put shrink wrap around it..still holding after 1 1/2 years!
N201MKTurbo Posted December 7, 2025 Report Posted December 7, 2025 1 hour ago, Buckster said: Last time I looked for a replacement they were sold out. I took the broken one and used epoxy and then put shrink wrap around it..still holding after 1 1/2 years! Do they have electrical conductivity to the airframe? If not, they are just decorative. 1
Buckster Posted December 8, 2025 Report Posted December 8, 2025 27 minutes ago, N201MKTurbo said: Do they have electrical conductivity to the airframe? If not, they are just decorative. Yes, The carbon core in mine are designed to allow electricity to control the rate of static charge dissipation. If struck by lightning, they provide a path for the massive current to hopefully safety exit the aircrafts structure.
N201MKTurbo Posted December 8, 2025 Report Posted December 8, 2025 8 minutes ago, Buckster said: Yes, The carbon core in mine are designed to allow electricity to control the rate of static charge dissipation. If struck by lightning, they provide a path for the massive current to hopefully safety exit the aircrafts structure. You said you repaired them with epoxy. Did you test them after you repaired them?
N201MKTurbo Posted December 8, 2025 Report Posted December 8, 2025 They are designed to dissipate static buildup from P-static. They have nothing to do with lightning protection. 2
N201MKTurbo Posted December 8, 2025 Report Posted December 8, 2025 You can buy new ones from spruce for $35. They are not certified, but who would know or care. 3
Buckster Posted December 24, 2025 Report Posted December 24, 2025 On 12/7/2025 at 7:35 PM, N201MKTurbo said: You said you repaired them with epoxy. Did you test them after you repaired them? I used the epoxy on the outer perimeter. The epoxy can't be applied between the carbon fibers because the epoxy would act like an insulator and the wick would be considered useless. I did this because at the time I could not find the exact replacement as suppliers were "out of stock"
Slick Nick Posted December 24, 2025 Report Posted December 24, 2025 On 12/7/2025 at 5:49 PM, N201MKTurbo said: You can buy new ones from spruce for $35. They are not certified, but who would know or care. The new style 4" rigid ones? I can't find them. Had to go through LASAR.
