Try using the Target=_blank option when you add the link.
If the forums supports html then writing it would look something like this:
(edit)
<@ href="http://picasaweb.google.com/n223mm/N223MM#5350136815695072994" target="_blank">161 TAS @ 9500
Replace @  and /@ with an a and /a.  I only out this in because the software IS recognizing it and creating a link out of "target=..."
(end edit)
Here is what it looks like with the pop up box method.  Notice that it does not keep my prefered "Title" of "161 TAS @ 9500"  http://picasaweb.google.com/n223mm/N223MM#5350136815695072994
That could be a bug in the forum software or an operator error - not sure at this point. Either way - it does open a new browser window in IE7.
