Kodiakflyer Posted August 23, 2024 Report Posted August 23, 2024 Does anyone have a source for the 3CRE-714 shock disc?
Sabremech Posted August 24, 2024 Report Posted August 24, 2024 Those are the old Firestone disks and are un-obtainium new. I just removed a set from my M20 and am complying with Mooney S/B M20-161 to install the later style Lord disks. David
Kodiakflyer Posted August 27, 2024 Author Report Posted August 27, 2024 Which model do you have David? Mine is an A. Tom Kodiakflyer@gmail.com
Kodiakflyer Posted August 27, 2024 Author Report Posted August 27, 2024 Never mind David. I read your thread. My project is similar 30 months in and have not made it public. 4
Kodiakflyer Posted August 27, 2024 Author Report Posted August 27, 2024 David, have you located the parts required to comply with M20-161? The Lord discs are easy...Spruce. It's the rest...
Sabremech Posted August 28, 2024 Report Posted August 28, 2024 10 hours ago, Kodiakflyer said: David, have you located the parts required to comply with M20-161? The Lord discs are easy...Spruce. It's the rest... Hi Tom, I purchased the used parts I needed from Alan Fox. I believe he’s on MS but can message you his contact info if needed? Thanks, David
Sabremech Posted August 28, 2024 Report Posted August 28, 2024 22 hours ago, Kodiakflyer said: Never mind David. I read your thread. My project is similar 30 months in and have not made it public. Great looking bird!
LANCECASPER Posted August 28, 2024 Report Posted August 28, 2024 17 hours ago, Sabremech said: Hi Tom, I purchased the used parts I needed from Alan Fox. I believe he’s on MS but can message you his contact info if needed? Thanks, David @Alan Fox
Kodiakflyer Posted November 23, 2024 Author Report Posted November 23, 2024 Hi Alan, sorry for the late reply. I don't visit this BB often. Wentworth had C gear that I scavenged the parts that I needed from. After cleaning, inspecting and painting, they look and fit up perfectly. Tom
