FloridaMan Posted April 23, 2024 Report Posted April 23, 2024 Mine appears to be stripped. Anyone have the Spruce link for the right part? Quote
PT20J Posted April 23, 2024 Report Posted April 23, 2024 https://www.saf-air.com/products/oil-valves/oil-valve-chart.html Not sure what you mean by stripped. If the threads are damaged in the sump, it might be a bigger issue. But this is unlikely unless it was removed and cross threaded. 1 Quote
FloridaMan Posted April 24, 2024 Author Report Posted April 24, 2024 On 4/22/2024 at 11:23 PM, PT20J said: https://www.saf-air.com/products/oil-valves/oil-valve-chart.html Not sure what you mean by stripped. If the threads are damaged in the sump, it might be a bigger issue. But this is unlikely unless it was removed and cross threaded. I mean that it won't engage. I imagine the quick drain as having a pin pressed into the side that follows a J-shaped cut in the side of the base and that the pin is sheared. Quote
PT20J Posted April 24, 2024 Report Posted April 24, 2024 1 hour ago, FloridaMan said: I mean that it won't engage. I imagine the quick drain as having a pin pressed into the side that follows a J-shaped cut in the side of the base and that the pin is sheared. The description sounds like a damaged Saf-Air drain. Quote
